Chuck B 2004 Windsor Posted July 5, 2021 Share Posted July 5, 2021 The flat telephone type sensor wire is not able to be spliced because its not a solid wire. That type of wire is subject to induced cross talk because the wire is not twisted. The RV manufacturers us that wire because it's a lot cheaper. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
vito.a Posted July 5, 2021 Share Posted July 5, 2021 Yes but you can crimp a new connector on the cable as well as the sensor and then use a coupler. Link to comment Share on other sites More sharing options...
JDCrow Posted July 5, 2021 Share Posted July 5, 2021 16 minutes ago, vito.a said: Yes but you can crimp a new connector on the cable as well as the sensor and then use a coupler. I would think so. I create my own Cat 5/6 cables all the time for Poe cameras Link to comment Share on other sites More sharing options...
Biljol Posted July 6, 2021 Share Posted July 6, 2021 I have done this kind of the magnum uses a straight cable and the trace used a flip cut the end off and crimp a new rj11. I also switched to lithium and did not need the temp sensor clipped off and used for a shunt. Link to comment Share on other sites More sharing options...
