Bob R Posted July 12, 2021 Share Posted July 12, 2021 My G2000 awning will not extend using the electric motor. I can manually extend the awning and it will retract using the motor drive. Has anyone experienced this problem? If so how was the problem solved? Link to comment Share on other sites More sharing options...
Biljol Posted July 17, 2021 Share Posted July 17, 2021 I have the same problem right now on mine I am able to Hotwire it a the control box and get it to extend so not the motor. Had to leave on a trip so not digging into it right now. Link to comment Share on other sites More sharing options...
wamcneil Posted July 18, 2021 Share Posted July 18, 2021 Are you getting voltage on the motor leads? There are two little relays soldered onto the the control board, one for motor extend and one for retract. One of mine was sketchy and I could hear it click when I hit the button, but the motor would often fail to retract. I could verify 125v going to the relays, but no voltage to the motor output when the relay clicked. cheers Walter Link to comment Share on other sites More sharing options...
cureinc1 Posted July 19, 2021 Share Posted July 19, 2021 Had the same problem. Called Girard. Here is the fix. How to fix Girard awning Locate control boxes Turn off power at breaker Locate ACL Current Limiter box Open the junction box. there are 4 wires in and r wires out. All the same color. remove the control board and wire the four wires in to the 4 wires out to each other of the same color. Should be Green white black & red. Use butt connectors. Use the junction box to keep the butt connectors in Ernest Cuaron 07 Signature 21 Grand Cherokee Summit 1 Link to comment Share on other sites More sharing options...
Paul J A Posted July 19, 2021 Share Posted July 19, 2021 1 hour ago, cureinc1 said: Had the same problem. Called Girard. Here is the fix. How to fix Girard awning Locate control boxes Turn off power at breaker Locate ACL Current Limiter box Open the junction box. there are 4 wires in and r wires out. All the same color. remove the control board and wire the four wires in to the 4 wires out to each other of the same color. Should be Green white black & red. Use butt connectors. Use the junction box to keep the butt connectors in Ernest Cuaron 07 Signature 21 Grand Cherokee Summit THank you for that post. Talking to the Mfg. usually provides the needed infomation for the issue at hand. Sure beats speculations and opinions. Link to comment Share on other sites More sharing options...
wamcneil Posted July 20, 2021 Share Posted July 20, 2021 I hope yours turns out to be that simple! I called them when mine acted up and those were the instructions they gave me too… 😕 Apparently they had a bunch of current limiter failures… but there are other failure points. cheers Walter Link to comment Share on other sites More sharing options...
tskrub1 Posted November 6, 2022 Share Posted November 6, 2022 I recently purchased an 04 windsor knowing the awning did not work. If I press the switch or the remote I can hear what I assume is the motor turning, but awning is not moving. It makes me believe that something has stripped and needs to be replaced. I have searched high and low to try and find a way to retract the awning but have been unsuccessful. Could someone please help me with the process for this? Thanks, Tim. 04 Monaco Windsor Sorry, I meant to say "extend" the awning. Link to comment Share on other sites More sharing options...
jacwjames Posted November 6, 2022 Share Posted November 6, 2022 1 hour ago, tskrub1 said: I recently purchased an 04 windsor knowing the awning did not work. If I press the switch or the remote I can hear what I assume is the motor turning, but awning is not moving. It makes me believe that something has stripped and needs to be replaced. I have searched high and low to try and find a way to retract the awning but have been unsuccessful. Could someone please help me with the process for this? Thanks, Tim. 04 Monaco Windsor Sorry, I meant to say "extend" the awning. Do you know what model awning you have???? Link to comment Share on other sites More sharing options...
tskrub1 Posted November 7, 2022 Share Posted November 7, 2022 Sorry, I meant to say "extend" the awning. It is a carefree of colorado. I believe the access is on top but i was unable to access it because of the slide topper. I used a hole saw from underneath and luckily drilled in the right location. I was able to extend it and see the manufacturer, serial number and part number. Still having trouble finding the part number for the motor though. Once I get the motor replaced I will make a cover plate for the hole I cut. Thanks for responding Link to comment Share on other sites More sharing options...
jacwjames Posted November 7, 2022 Share Posted November 7, 2022 What model of Carefree of Colorado do you have? Link to comment Share on other sites More sharing options...
tskrub1 Posted November 7, 2022 Share Posted November 7, 2022 Link to comment Share on other sites More sharing options...
jacwjames Posted November 7, 2022 Share Posted November 7, 2022 Can you take a picture of the whole side mount arm Based on the SN you have a Mirage https://www.e-carefree.com/ecarefree30/catalog?search=2042865821 You can look up parts and get a copy of the manual. I believe this is a 120 volt motor but has 12 volt switching. So it might be something electrical. It also shows that the awning can be extended using a hand crank. I took a quick look and the motor PN is R001853, still available, cheapest one I saw on Ebay was ~$1000. So I would do some troubleshooting and confirm the problem. Could be a fuse or connection issue. Link to comment Share on other sites More sharing options...
