ktloah Posted July 25, 2021 Share Posted July 25, 2021 Hello campers, while traveling home we lost our low beam side of the headlights. Marker lights flashed and they went out. Could not find any fuse, relay in the left front compartment. Checked the engine bay too. 04 Dynasty...400 isl...any suggestions? Link to comment Share on other sites More sharing options...
Ivylog Posted July 25, 2021 Share Posted July 25, 2021 Welcome to the burnt plug on the smart wheel controller in the front run box. I bypassed the 2 burnt wires with a 2 conductor plug (like the 4 type used for trailer lights). Soldered it into the board that was burnt up. Link to comment Share on other sites More sharing options...
Tim-AZ Posted July 25, 2021 Share Posted July 25, 2021 If you have an access panel on top of your dash look at the back of your light switch and make sure it's not melted. Link to comment Share on other sites More sharing options...
klcdenver Posted July 25, 2021 Share Posted July 25, 2021 There are several good past articles on this subject in here if you will do a search. Link to comment Share on other sites More sharing options...
ktloah Posted July 25, 2021 Author Share Posted July 25, 2021 Thanks for all the help....I'll post what the problem is when I find out... Link to comment Share on other sites More sharing options...
milly59 Posted August 4, 2021 Share Posted August 4, 2021 i have exact same problem but cannot find a solution, my intermittent wipers stopped working...my flashers do not work...my hazards do not work...is it the controller box under the dash that is the culprit? Ktloah did you find the problem? Link to comment Share on other sites More sharing options...
Ivylog Posted August 4, 2021 Share Posted August 4, 2021 If your Dip was made by Navastar the controller should be on the left wall of the front run box. Try cleaning the plug at the bottom of the steering column. Link to comment Share on other sites More sharing options...
ktloah Posted August 7, 2021 Author Share Posted August 7, 2021 Michel, I did find the problem with no low beams...it was the J12 plug on the smart wheel controller. Ran new wires to a separate relay, and it works just fine. There are multiple replies on how to....good luck! 04 Dynasty Link to comment Share on other sites More sharing options...
