Bill C Posted January 29, 2023 Share Posted January 29, 2023 My switch has 6 wires, not sure what they all do, but will try and look them up Link to comment Share on other sites More sharing options...
Dr4Film Posted January 29, 2023 Share Posted January 29, 2023 (edited) 13 hours ago, Corkman said: Can you share how you did that Richard? I have added a series of photos that I had saved from some other RVer who had done this previously. I also added photos of the LED lamps I had purchased from Fry's Electronics when I was living in CA. You have to be careful when disassembling the switch so not to break the little clips holding the rocker cover onto the body. Plus, I chose to add the resistor to the wiring harness instead of inside the switch body. I also tried various levels of resistors to see which one I liked for lamp brightness. 12 hours ago, Corkman said: My switch has 6 wires, not sure what they all do, but will try and look them up The switch in my previous Windsor had four wires. There are only two functions of the Aqua-Hot diesel switch. One is to turn on the Webasto system, two wires, and the other is to light up a lamp to indicate whether the system is in active mode or has defaulted, two wires. When the system defaults the indicator lamp turns off. Edited January 29, 2023 by Dr4Film Link to comment Share on other sites More sharing options...
