pwhittle Posted August 17, 2021 Share Posted August 17, 2021 I’ve had my ScanGauge D for a couple years plugged into the diagnostic port by drivers left knee, but last trip it was not working. Display was blank. I also tried plugging into the engine bay diagnostic port. Engine and transmission data is available via the Aladdin system. I called ScanGauge and described my problem. They had me send it in to have it checked out. They found no issue, but sent a different unit back, which also doesn’t work. Has anyone else had the same issue? Paul Link to comment Share on other sites More sharing options...
Ivan K Posted August 17, 2021 Share Posted August 17, 2021 Mine works fine. I have it on Auto-ON which turns it on when the voltage changes and sometimes with solar charger working it does not register and remains blank until I push whatever button. Doubt that would be your problem however. Link to comment Share on other sites More sharing options...
Yoaks5 Posted August 17, 2021 Share Posted August 17, 2021 On my 04 navigator I would lose connection on my blue fire plugged into the diagnostic port but the Aladdin would also shut off at the same time. Found a broken ground going from the diagnostic plug in the engine bay to the starter. You could try plugging into the port in the engine bay. If it still doesn't work I would test the ports. You can look this procedure up on line. Link to comment Share on other sites More sharing options...
Ivan K Posted August 17, 2021 Share Posted August 17, 2021 Mine works fine. I have it on Auto-ON which turns it on when the voltage changes and sometimes with solar charger working it does not register and remains blank until I push whatever button. Doubt that would be your problem however. My chart shows Diagnostics power fuse (1 amp) in chassis fuse section in FRB. I don't know if it is actually used and I never had to trace it but might be worth a look. It is a different fuse from ABS diagnostics so it might... Link to comment Share on other sites More sharing options...
pwhittle Posted August 19, 2021 Author Share Posted August 19, 2021 Thanks for the pointer @Ivan K I checked the 1A fused marked DGN PWR and found it was blown. I replaced it and the ScanGauge D started working again. Thanks also to ScanGauge who provided unquestioning support for a product that was nearing the end of a long warranty period. One piece of data I would really like to display on this is the transmission gear selected. It is available on the Aladdin, and is not a standard field on the ScanGauge D, so I will scan the PID data again and check with ScanGauge to see if it is available as a X-Gauge. Paul Link to comment Share on other sites More sharing options...
