hopcollin Posted August 19, 2021 Share Posted August 19, 2021 Been a long while since I was on this forum, twice cancer survivor Thanx to the Mayo Clinic in Jacksonville Fl. Robotic lung cancer surgery in 2018, and radiation treatments for prostate cancer in 2019. Praise the Lord can get back on the road! My 1994 Monaco Dynasty 38" center door we call the "Tumbleweed" is having dash a/c issues, like it doesn't work at all, Front Run Bay all fuses good but thought that there were fuses or relays in the Rear Run Bay also, unfortunately have lost that schematic. Can anybody point me to or provide for me a copy of that Rear Run Bay schematic for a 1994 Dynasty? Many thanx in advance, Hop and Marja Collin, 94 Dynasty pushed along by a 2009 Honda Fit Link to comment Share on other sites More sharing options...
cbr046 Posted August 19, 2021 Share Posted August 19, 2021 Have you checked AC system pressure? Even without the compressor kicking in, which it won't if refrigerant is low enough, there should be xx psi in the system. I don't know xx value. - bob Link to comment Share on other sites More sharing options...
Jim Bob Posted August 19, 2021 Share Posted August 19, 2021 Congrats on the CA battle!!! I'd love to have the schematics for my 95 also, if they are out there. Does everyone name their coach? I thought I was an odd ball for calling her Roxy. Link to comment Share on other sites More sharing options...
rpasetto Posted August 19, 2021 Share Posted August 19, 2021 The files section has two wiring files which, may be close to your '94 Dynasty. Hope these help. Congrats on your battle with Ca! Blessings and safe and healthy travels. Link to comment Share on other sites More sharing options...
dandick66 Posted August 20, 2021 Share Posted August 20, 2021 Congratulations on beating the cancer. I can’t help with the wiring diagram, but like CBR046 said, if the pressure is low, the compressor won’t kick in. Does your blower work? If so, the problem may very well be low pressure. It sounds like the coach hasn’t been used in 2-3 years and you probably have a leak. Since your coach is a 1994, you might still be using R12. If that’s the case, you will need to take it to a shop because R12 is no longer available. They will probably be able to do a R134 conversion. If your system uses R 134, you can pick up a can of refrigerant with a hose and gauge at an auto parts store or Walmart for about $30. It may not be enough refrigerant for the system, but it might be enough to get the compressor to kick in. Gd luck. Dan D Link to comment Share on other sites More sharing options...
dennisbroad@shaw.ca Posted August 21, 2021 Share Posted August 21, 2021 Hop, I have wiring diagrams for my 95 Dynasty. Do you still need the diagram for the rear run bay? I could scan it and email if you want it. Dennis Link to comment Share on other sites More sharing options...
