Duanebalogh Posted September 2, 2021 Posted September 2, 2021 We have a 2006 monaco signature motorhome and our entry key pad number 9 doesn't work and we need it to change the code. Where could I get a new entry key pad.
RS lakeshore Posted September 2, 2021 Posted September 2, 2021 Visoner RV is a salvage yard that might have one. I need to replace my keypad also and have found a replacement at A 1 electric .com. They are a distributor for Essex who makes the key pad. Check it out and let me know what you think.
Duanebalogh Posted September 2, 2021 Author Posted September 2, 2021 2 hours ago, RS lakeshore said: Visoner RV is a salvage yard that might have one. I need to replace my keypad also and have found a replacement at A 1 electric .com. They are a distributor for Essex who makes the key pad. Check it out and let me know what you think. Thanks I'll try that
vito.a Posted September 2, 2021 Posted September 2, 2021 Keypads have a finite life span as they are exposed to sun and elements. I would not purchase a used one. 2006 was a transition year. You need to determine if you have an Trimark or Essex keypad. If Trimark then contact them for a replacement. https://www.trimarkcorp.com/en/zPlatFormList.aspx?intcategoryid=173&topcategoryid=3&scategoryid=174&bannerurl=Elec_banner_eask.swf&gclid=Cj0KCQjw7MGJBhD-ARIsAMZ0eet_Zk13VqvoN2bC34PJXu2RjPmdb9xppCPaDaEuj0LwXcvSScomsJwaAjDiEALw_wcB If Essex, then A1 Electric in Torrance CA has the KE-1701BHC keypad with the original Monaco connector. 1
Duanebalogh Posted September 2, 2021 Author Posted September 2, 2021 3 hours ago, RS lakeshore said: Visoner RV is a salvage yard that might have one. I need to replace my keypad also and have found a replacement at A 1 electric .com. They are a distributor for Essex who makes the key pad. Check it out and let me know what you think. Another question how do I get the key pad out
Duanebalogh Posted September 2, 2021 Author Posted September 2, 2021 6 hours ago, RS lakeshore said: Visoner RV is a salvage yard that might have one. I need to replace my keypad also and have found a replacement at A 1 electric .com. They are a distributor for Essex who makes the key pad. Check it out and let me know what you think. Got our keyless pad out and it was an Essex. Ordered it from A-1 electric in Torrance, ca. A little shocked by the price $350.00 . We have Corner Stone extended warranty so I looked up my warranty and sure enough it was covered. I called and because I ordered it and will plug it in ourselves they will not cover it. They said we shoukd have had a dealer look at it and send a quote. I'm so mad. My deductible is $200 so they woukd pay 150.00. It would have cost them more than that by the time they paid for a electrician to look at it. I woukd never recommend Cornerstone warranty to any one. Look very closely at your warranty if you have one.
RS lakeshore Posted September 3, 2021 Posted September 3, 2021 Does your keypad have a lock button? Mine does and I contacted Trimark and was told it wasn't one of theirs. They recommended I contact Essex because the one I have is obsolete. How many wires are on your keypad mine has 5 and is attached to a 4 wire connector. Thanks
