Terry S Posted April 1, 2022 Share Posted April 1, 2022 Hi Bill, I'm not familiar with your hydraulic slide but a similiar problem on my 2002 Monarch. It turned out to be the bolt that connects the drive shaft to the square tubing on the slide. Don't know if this applies to your coach but thought it was worth mentioning. Terry Link to comment Share on other sites More sharing options...
96 EVO Posted April 1, 2022 Share Posted April 1, 2022 Recently went thru a similar situation. One of the solenoids was warm (energized) when it shouldn't be. Unplugged that solenoid and was able to retract the slide. Link to comment Share on other sites More sharing options...
Bill C Posted April 1, 2022 Author Share Posted April 1, 2022 Update: 1 Apr 2022 Good Day Everyone, thank you all for your suggestions and feedback. I made it to the campground and after testing the solenoids and tracing the voltages, I discovered that a wire on the slide in/out switch had come off, apparently the wire for the slide "out". It was lose and easily came off so I crimped it with pliers so that it would not easily slide off the switch again. I was just thankful that the fix was so easy. Perhaps I should have started at the switch first 🙂 Thanks again, Bill Link to comment Share on other sites More sharing options...
jacwjames Posted April 1, 2022 Share Posted April 1, 2022 Good news, glad you got it fixed. Link to comment Share on other sites More sharing options...
BradHend Posted April 2, 2022 Share Posted April 2, 2022 Well I’m glad you started with the basics and found the problem. Nice job. Safe travels. Link to comment Share on other sites More sharing options...
