BradHend Posted May 1, 2022 Share Posted May 1, 2022 Hi folks, In my pursuit of trying to get a smoother ride out of my R4R chassis - so far I’ve really only just changed the shocks - which did help tremendously with the smaller bumps and what not, I have come to the conclusion that this coach I bought last year is riding under the manufacturer specs with regards to ride height. It’s been this way since I bought it - but ultimately the front is 1” low and the rear is 3/4” low according to the manual. I’m measuring between the steel plates of the airbags, and I’m just wondering if this is one of those cases where if it’s been like this for a long time, would I be causing premature stresses and wear by changing it to what the manual is recommending, or just leave it and change it if/when I replace the four airbags. Would love to hear some thoughts on this. Thanks. Link to comment Share on other sites More sharing options...
gdroberson Posted May 2, 2022 Share Posted May 2, 2022 my mh rear bags are a inch lower than what the book says but if I hold the right height rod and try to raise it it will only go up about a 1/4 inch and is maxed out so I just left it alone Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted May 2, 2022 Share Posted May 2, 2022 FYI, the Roadmaster R4R chassis has been recalled due to failing trailing arms failure. http://sourcerv.com/RoadmasterR4R_FMC1109.pdf Link to comment Share on other sites More sharing options...
gdroberson Posted May 2, 2022 Share Posted May 2, 2022 that not the problem I have replaced the bags and shocks and been over every thing with a fine tooth comb I think it was the way it was built the book is for a 32 f00t mh mine is a 30 Link to comment Share on other sites More sharing options...
BradHend Posted May 2, 2022 Author Share Posted May 2, 2022 Thanks Chuck, I am well aware of that and that was one of my questions to the previous owner during the sale. My Cayman has been outfitted with the Source Engineering trailing arm kit. Link to comment Share on other sites More sharing options...
Ivan K Posted May 2, 2022 Share Posted May 2, 2022 I'd say at the rear it depends on how much you care about driveshaft angle for u-joint life. Usual recommendation is 1-3° angle. In my case, with 32" driveshaft, a 3/4" deviation would add or remove 1.3° from the correct, lets assume 2° setting. Not horrible. That angle is constantly changing as you drive, unless Canadian roads are like glass. Just keep up with the grease job. Both front and rear hights will effect steering caster but given the distance between axles, very little and given that both are low, there is no practical change in that sense. Link to comment Share on other sites More sharing options...
