sg47619 Posted May 27, 2022 Share Posted May 27, 2022 Has anyone ever rewound the spring on a omaga 1 topper ? I put a new fabric on it and now it won’t retract. Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted May 27, 2022 Share Posted May 27, 2022 You tube should have a video on it. I have the carefree of Colorado awning. Link to comment Share on other sites More sharing options...
sg47619 Posted May 27, 2022 Author Share Posted May 27, 2022 15 minutes ago, Bob Schmeckpeper said: You tube should have a video on it. I have the carefree of Colorado awning. Thank you I’ll look it up tonight. Link to comment Share on other sites More sharing options...
Gary M Posted May 27, 2022 Share Posted May 27, 2022 Call Stone Vos. They should be able to clue you in on how many rotations to start with. 352-942-0224 710 South Main Street Brooksville, FL 34601 Link to comment Share on other sites More sharing options...
sg47619 Posted May 27, 2022 Author Share Posted May 27, 2022 3 minutes ago, Gary M said: Call Stone Vos. They should be able to clue you in on how many rotations to start with. 352-942-0224 710 South Main Street Brooksville, FL 34601 Thanks I’ll do that Monday Link to comment Share on other sites More sharing options...
gjh2916 Posted May 28, 2022 Share Posted May 28, 2022 Rule of thumb length of awning/topper by feet plus 7 equals amount of turns Link to comment Share on other sites More sharing options...
Gary M Posted May 28, 2022 Share Posted May 28, 2022 1 hour ago, gjh2916 said: Rule of thumb length of awning/topper by feet plus 7 equals amount of turns Is that for all toppers or just the Omega? I have SOKIII’s. Link to comment Share on other sites More sharing options...
MHRookie Posted May 28, 2022 Share Posted May 28, 2022 You should be able to Google and get the instructions. You prewind the tube and use filter wrench to hold in place and insert fabric. I believe it was 15 turns to preload. You can also take the right arm loose and wind more if it needs it later, it’s just not as convenient. Link to comment Share on other sites More sharing options...
gjh2916 Posted May 29, 2022 Share Posted May 29, 2022 20 hours ago, Gary M said: Is that for all toppers or just the Omega? I have SOKIII’s. This is just something I have used over the years and years of Rving and it seems to work 1 Link to comment Share on other sites More sharing options...
sg47619 Posted May 29, 2022 Author Share Posted May 29, 2022 14 hours ago, MHRookie said: You should be able to Google and get the instructions. You prewind the tube and use filter wrench to hold in place and insert fabric. I believe it was 15 turns to preload. You can also take the right arm loose and wind more if it needs it later, it’s just not as convenient. I already but the fabric on the topper Link to comment Share on other sites More sharing options...
Gary M Posted May 29, 2022 Share Posted May 29, 2022 45 minutes ago, sg47619 said: I already but the fabric on the topper My SOKIII have an alignment hole on the right side and all I do is insert a 3” cotter pin and slightly spread the end so it wind fall out. Fabric should have about 3/4” clearance on each end. I just rotate inward slightly till I can insert the pin. Then it’s locked to the spring. Then I remove topper and roller and move slide in 4 to 8 inches, hand roll topper on roller and reset into ends. 8” is close to one rotation of roller. That’s how I was told to put more tension to keep topper taught. Link to comment Share on other sites More sharing options...
MHRookie Posted May 29, 2022 Share Posted May 29, 2022 9 hours ago, sg47619 said: I already but the fabric on the topper They you will have to put out the slide then take the arm loose on right side and wind it. The instructions will tell you how to do it. Link to comment Share on other sites More sharing options...
sg47619 Posted May 29, 2022 Author Share Posted May 29, 2022 2 hours ago, MHRookie said: They you will have to put out the slide then take the arm loose on right side and wind it. The instructions will tell you how to do it. 2 hours ago, MHRookie said: They you will have to put out the slide then take the arm loose on right side and wind it. The instructions will tell you how to do it. Where do I fine the instructions at ? Link to comment Share on other sites More sharing options...
MHRookie Posted May 30, 2022 Share Posted May 30, 2022 The internet and YouTube are wonderful tools. Carefree Spring Chart - Change & Tension.pdf 2 Link to comment Share on other sites More sharing options...
bonfield Posted May 30, 2022 Share Posted May 30, 2022 I an replacing the spring on my slides topper can any one give me the direction to tighten it up. I beleive it is an omega 11 not sure. The numbers on the tube are DT ;4057 SN; 2042860277 PN; uj148emjb429 Link to comment Share on other sites More sharing options...
Gary M Posted May 30, 2022 Share Posted May 30, 2022 (edited) 36 minutes ago, bonfield said: I an replacing the spring on my slides topper can any one give me the direction to tighten it up. I beleive it is an omega 11 not sure. The numbers on the tube are DT ;4057 SN; 2042860277 PN; uj148emjb429 I have to thank Kurt for this. Edited May 30, 2022 by Gary M Link to comment Share on other sites More sharing options...
bonfield Posted May 30, 2022 Share Posted May 30, 2022 Trouble is i do not know which one mines is because the two choices one is clockwise the other is anticlockwise.sok ii or omega Link to comment Share on other sites More sharing options...
Gary M Posted May 30, 2022 Share Posted May 30, 2022 2 hours ago, bonfield said: I an replacing the spring on my slides topper can any one give me the direction to tighten it up. I beleive it is an omega 11 not sure. The numbers on the tube are DT ;4057 SN; 2042860277 PN; uj148emjb429 Call Carefree Colorado with part numbers and maybe they can help you. Link to comment Share on other sites More sharing options...
MHRookie Posted May 30, 2022 Share Posted May 30, 2022 2 hours ago, bonfield said: Trouble is i do not know which one mines is because the two choices one is clockwise the other is anticlockwise.sok ii or omega Try using this…Carefree_omega_slide_awning_Removal.pdf 2 hours ago, Gary M said: Call Carefree Colorado with part numbers and maybe they can help you. Link to comment Share on other sites More sharing options...
