Craggar Posted July 15, 2022 Share Posted July 15, 2022 Maybe I'm missing something but without a pump how do I get the bleach or whatever I use into my fresh water tank? Link to comment Share on other sites More sharing options...
Land Lubber Posted July 15, 2022 Share Posted July 15, 2022 4 minutes ago, Craggar said: Maybe I'm missing something but without a pump how do I get the bleach or whatever I use into my fresh water tank? I have put bleach in my fresh water hose then hooked up to the fresh water inlet connection then turned on the water to fill the tank. This will sanitize your hose too. Another way is if you have an extra water filter housing, ensure there isn't a filter in it, put the bleach in it then connect it inline & turn on the water. Link to comment Share on other sites More sharing options...
RVhorod Posted July 15, 2022 Share Posted July 15, 2022 On our 2000 Dynasty I have to use a pump. Bought an inexpensive small volume pond pump. Works great. Link to comment Share on other sites More sharing options...
Craggar Posted July 15, 2022 Author Share Posted July 15, 2022 Thanks for the speedy reply. I never thought until now I can use my spare water pump I keep in the rv. Link to comment Share on other sites More sharing options...
Jim McGarvie Posted July 15, 2022 Share Posted July 15, 2022 17 minutes ago, Land Lubber said: I have put bleach in my fresh water hose then hooked up to the fresh water inlet connection then turned on the water to fill the tank. This will sanitize your hose too. Another way is if you have an extra water filter housing, ensure there isn't a filter in it, put the bleach in it then connect it inline & turn on the water. I too put bleach in the hose then fill the tank. Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted July 15, 2022 Share Posted July 15, 2022 I guess I'm lucky, I have a gravity fill port. Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted July 15, 2022 Share Posted July 15, 2022 Why fool around with a pump just pour it into an empty water hose. You don't need but about a cup full. Link to comment Share on other sites More sharing options...
Craggar Posted July 15, 2022 Author Share Posted July 15, 2022 2 minutes ago, Ray Davis said: Why fool around with a pump just pour it into an empty water hose. You don't need but about a cup full. I might do it that way next time but I have a two part kit sold by Thetford that I will need to use 40 oz.'s of it for my tank that I'm going to try this time. I already have one hose made that I use to put the antifreeze in the rv for winter so one more hose is easy and the plug for the pump is close enough I don't need to use a battery to run it. Link to comment Share on other sites More sharing options...
cbr046 Posted July 15, 2022 Share Posted July 15, 2022 I've done the bleach-in-hose trick to get the sulfur smell out of the hot water tank. That was on the old gasser. The HR HW tank doesn't seem to stink up as much. - bob Link to comment Share on other sites More sharing options...
Notn2bars Posted July 15, 2022 Share Posted July 15, 2022 Ditto Ray, pour into the fresh water hose or remove one of your filter housings and pour the bleach into it. God Bless, Ed & Sylvia Link to comment Share on other sites More sharing options...
thomasgibbens Posted July 16, 2022 Share Posted July 16, 2022 I do this when I change my water filter element by unscrewing the housing, removing the filter and put the proper amount of Clorox in the container and then screw it back on. Then I fill the fresh water tank. First though, I drain the fresh water tank. TGibbens 15 Dynasty Link to comment Share on other sites More sharing options...
