Jcparmley Posted September 16, 2022 Share Posted September 16, 2022 Hello All I am wondering if a Series 60 will fit in a 1997 Monaco Executive with a M11 Cummins? Link to comment Share on other sites More sharing options...
SigPIlot Posted September 16, 2022 Share Posted September 16, 2022 If it doesn't you can buy my 04 Sig with a DD60 (lol) Link to comment Share on other sites More sharing options...
Flyinhy Posted September 16, 2022 Share Posted September 16, 2022 I'm sure it can be done. I've seen a Volkswagen beetle with a ls6 , the question is why? The cost of a retrofit in a 97 sig vs a stock swap wouldn't seem economical to me. 🤔 1 Link to comment Share on other sites More sharing options...
vito.a Posted September 16, 2022 Share Posted September 16, 2022 Monaco offered the Detroit Series 60 in the Signature starting in 2004 and the Executive and Navigator in 2005. This was a very expensive option ($24-26k) when new but there are usually some for sale on the used market. To retrofit a Series 60 to a 97 coach would be difficult and expensive. The Detroit is computer controlled as is the Allison MH4000 mated to it.  A swap would require the ECU for both the engine and trans plus all the wire harnesses. Wiring and setting up the throttle and cruise control would be a huge task. The Detroit 60 is heavier than the M11 so the rear axle without a tag would be overloaded.  Your best path would be to search for a good used coach with the Detroit.  1 Link to comment Share on other sites More sharing options...
Mike H Posted September 16, 2022 Share Posted September 16, 2022 My '05 Exec has the Detroit 60 in it. Link to comment Share on other sites More sharing options...
Jcparmley Posted September 16, 2022 Author Share Posted September 16, 2022 Thanks. I was just asking because I have a series 60 from my bus and I was debating if I should keep it just in case I need an engine for the evening or sell it. Link to comment Share on other sites More sharing options...
Flyinhy Posted September 17, 2022 Share Posted September 17, 2022 Sell it for sure....have you seen the prices on food lately?????😳 1 Link to comment Share on other sites More sharing options...
throgmartin Posted September 17, 2022 Share Posted September 17, 2022 The costs to retrofit would be exorbitant. Just the wiring alone would be a complete nightmare. 1 Link to comment Share on other sites More sharing options...
