c210pa18 Posted September 17, 2022 Share Posted September 17, 2022 This is on a 2002 Monaco Signature ISM 500. It has a two stage exhaust brake. It seems to work as it should about 70% of the time. Can someone describe the circuit. There is a Brake HIgh/Low switch on the left driver panel. It has a momentary contact foot switch which I suppose could be going bad. What is the circuit from there? Is there a Bosch relay somewhere? I presume maybe there is a solenoid or maybe two on the engine. I am trying to trace it out to find where it is failing but do not have a diagram to help with that. Any help would be appreciated. Link to comment Share on other sites More sharing options...
Solution jjroxus Posted September 17, 2022 Solution Share Posted September 17, 2022 I have a 2002 signature as well. Check your foot switch continuity with a volt/ohm meter when pressed. If it shows any resistance it doesn’t work correctly. That was the case with mine. I replaced the foot switch and the jake works as it should. All the Best John J 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted September 17, 2022 Share Posted September 17, 2022 (edited) The foot switch is closed when you hold your foot on it which activates the engine brake. Then opens when you remove your foot to turn off the engine brake. I would first verify that the foot switch is not at fault, then work from there. Check the files section for a wiring diagram for your coach. Edited September 17, 2022 by Dr4Film 1 Link to comment Share on other sites More sharing options...
Frank McElroy Posted September 17, 2022 Share Posted September 17, 2022 28 minutes ago, c210pa18 said: This is on a 2002 Monaco Signature ISM 500. It has a two stage exhaust brake. It seems to work as it should about 70% of the time. Can someone describe the circuit. There is a Brake HIgh/Low switch on the left driver panel. It has a momentary contact foot switch which I suppose could be going bad. What is the circuit from there? Is there a Bosch relay somewhere? I presume maybe there is a solenoid or maybe two on the engine. I am trying to trace it out to find where it is failing but do not have a diagram to help with that. Any help would be appreciated. Here is a screen shot from our files of the wiring diagram for your system. Link to comment Share on other sites More sharing options...
c210pa18 Posted September 17, 2022 Author Share Posted September 17, 2022 Thanks for the quick replies. The foot switch does have some resistance so that is probably the problem. I have just now been searching for the part number PN 012260 and so far the first few places that come up are out of stock. I'll keep looking. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 17, 2022 Share Posted September 17, 2022 I purchased a momentary foot switch from Amazon made by Linemaster. Linemaster T-91-S Treadlite II Foot Switch, Electrical, Single Pedal, Momentary, SPDT, No Guard, Black https://a.co/d/6Ap34o5 Works great and rock solid. 1 Link to comment Share on other sites More sharing options...
c210pa18 Posted September 17, 2022 Author Share Posted September 17, 2022 I am finding the Linemaster and PacBrake foot switches but on the original. Good to know the LineMaster works no problem. Looks like that is what I'll order. Well that was easier than I expected. The foot switch has resistance and is intermittent so a new one will go in and it is supposed to be here Monday. Great help guys!! Thanks 1 Link to comment Share on other sites More sharing options...
c210pa18 Posted October 1, 2022 Author Share Posted October 1, 2022 Got the foot switch installed and just completed a 1100 mile trip. Jake Brake works perfectly now. Got a great chance to prove it on the looong down hill between Flagstaff and Phoenix yesterday. Thanks for the help! I incorrectly presumed the problem would be more complicated than it was. Nice when it turns out like that. Link to comment Share on other sites More sharing options...
