Gonzalo Posted October 5, 2022 Share Posted October 5, 2022 My Dash light for the entry step is on all the times I check connections ,I Lube the mechanism with silicone spray ,the entry door steps works fine in and out Any ideas thanks Gonzalo from NC Link to comment Share on other sites More sharing options...
Ivan K Posted October 5, 2022 Share Posted October 5, 2022 Check for couple of small gauge wires that might be going to a magnetic switch. Don't know your step and there's no coach model in your signature but our safety indicator switch is at the rear side of the step, the wheel side, and it has to come to a close proximity of a magnet when retracted. Both are just glued to the metal. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted October 5, 2022 Share Posted October 5, 2022 Ivan is correct. The magnetic alarm type window switch is out of adjustment. Link to comment Share on other sites More sharing options...
Gonzalo Posted October 5, 2022 Author Share Posted October 5, 2022 IT IS A 2005 Monaco Windsor 40 feet long with air leveling air bags Link to comment Share on other sites More sharing options...
David White Posted October 6, 2022 Share Posted October 6, 2022 9 hours ago, Gonzalo said: IT IS A 2005 Monaco Windsor 40 feet long with air leveling air bags Gonzalo, I have the same MH and as pointed out, the little magnetic switch is under the step. There is a wired half and another half that matches up when the step is closed. Put the step out to see if part has come off, but be careful because it can close and cause injury. When closed, the parts should be close together so the magnetic activates the switch and turn off the light. If the parts are in near contact and the light still stays on, it might be a faulty switch. Mine still gives be a light intermittently! Link to comment Share on other sites More sharing options...
Gonzalo Posted October 6, 2022 Author Share Posted October 6, 2022 8 minutes ago, David White said: Gonzalo, I have the same MH and as pointed out, the little magnetic switch is under the step. There is a wired half and another half that matches up when the step is closed. Put the step out to see if part has come off, but be careful because it can close and cause injury. When closed, the parts should be close together so the magnetic activates the switch and turn off the light. If the parts are in near contact and the light still stays on, it might be a faulty switch. Mine still gives be a light intermittently! I check the magnetic and I found two magnetic s switches on the entrance door and one is broke I think that's my problems it is two switches in one Link to comment Share on other sites More sharing options...
Ivan K Posted October 6, 2022 Share Posted October 6, 2022 9 minutes ago, Gonzalo said: I check the magnetic and I found two magnetic s switches on the entrance door and one is broke I think that's my problems it is two switches in one If the step goes in and out with the door, it isn't your problem, not for the step anyway. What you are looking for is a little switch outside on side of the step arms. Will have wires coming out of it. Link to comment Share on other sites More sharing options...
Gonzalo Posted October 6, 2022 Author Share Posted October 6, 2022 Ok I will check againg but I didn't fine any broke cables Link to comment Share on other sites More sharing options...
Ivan K Posted October 6, 2022 Share Posted October 6, 2022 58 minutes ago, Gonzalo said: Ok I will check againg but I didn't fine any broke cables The wires don't have to be necessarily broken, the switch that might look like a small rectangular plastic block might have shifted or the small magnet fell off. That's based on the way my step works, should be pretty generic principle. Link to comment Share on other sites More sharing options...
Tom Cherry Posted October 6, 2022 Share Posted October 6, 2022 Monaco replaced, under warranty, my switch and the tech glued it in. Mine was intermittent. As in if it had rained, it might be on for a while. The wiring gets corroded. If your plug and unplug the connectors and then use a bright light, you may see corrosion. A thin awl or ice pick will sometimes clean off the corrosion. Plugging any unplugging to abrade or polish the connector will sometimes clean it up. Most of the Monaco repair shops will also use the black RTV windshield rubber sealer and seal he back of the plugs….as well as the magnet housing. They also seal the wires going into the controller. Monaco’s extended warranty finally replaced my controller. As a Moderator, please update your profile and add your 2005 Windsor to it like most do. Thanks Link to comment Share on other sites More sharing options...
David White Posted October 6, 2022 Share Posted October 6, 2022 On 10/5/2022 at 10:35 AM, Gonzalo said: IT IS A 2005 Monaco Windsor 40 feet long with air leveling air bags Gonzalo, I have the same MH and as pointed out, the little magnetic switch is under the step. There is a wired half and another half that matches up when the step is closed. Put the step out to see if part has come off, but be careful because it can close and cause injury. When closed, the parts should be close together so the magnetic activates the switch and turn off the light. If the parts are in near contact and the light still stays on, it might be a faulty switch. Mine still gives be a light intermittently! Link to comment Share on other sites More sharing options...
Gonzalo Posted October 6, 2022 Author Share Posted October 6, 2022 I will look for the switch thanks Link to comment Share on other sites More sharing options...
Gonzalo Posted October 19, 2022 Author Share Posted October 19, 2022 I found this switch for my entry door light and step door Car Sliding Door Contact Switch Compatible with VW T3 T4 T5Car Sliding Door Contact Switch Compatible with VW T3 T4 T5 Only 3 left in stock - order soon. Eligible for FREE Shipping & FREE Returns This is a giftThis is a gift Learn more Qty: 0 (Delete) 12345678910+ Qty:1 Link to comment Share on other sites More sharing options...
