glang11082 Posted November 3, 2022 Share Posted November 3, 2022 Any one know where the front furnace fuse location is for a 2007 Knight or 2007 HD Ambassador? Mine was working fine when I turned it off but the next day nothing, checked voltage at furnace but its Zero. The thermostat is for both front and rear , the rear furnace is running ok. Appreciate all assistance Link to comment Share on other sites More sharing options...
Gary M Posted November 3, 2022 Share Posted November 3, 2022 I have an 09 Knight and my furnace fuse’s are inside above drivers seat. Link to comment Share on other sites More sharing options...
MurrayD Posted November 3, 2022 Share Posted November 3, 2022 I’ve got an 06 Knight and my fuses are in the closet beside the 120 volt panel Link to comment Share on other sites More sharing options...
Tom Cherry Posted November 3, 2022 Share Posted November 3, 2022 13 hours ago, glang11082 said: Any one know where the front furnace fuse location is for a 2007 Knight or 2007 HD Ambassador? Mine was working fine when I turned it off but the next day nothing, checked voltage at furnace but its Zero. The thermostat is for both front and rear , the rear furnace is running ok. Appreciate all assistance Reread your manual. The fuse in the house panel maybe (probably is ) for the thermostat controls only. If that fuse is OK and one furnace is running, then look for a reset button or check the panel. When you say voltage, are you describing VAC or VDC. If VAC, that will in the main panel. Your manual tells where the VAC and the VDC breakers and fuses are. Table of contents lists the equipment…..which may be the furnace or the house electrical. Sometimes info in both sections. Link to comment Share on other sites More sharing options...
glang11082 Posted November 6, 2022 Author Share Posted November 6, 2022 On 11/3/2022 at 12:09 AM, MurrayD said: I’ve got an 06 Knight and my fuses are in the closet beside the 120 volt panel On 11/3/2022 at 12:09 AM, MurrayD said: I’ve got an 06 Knight and my fuses are in the closet beside the 120 volt panel Just now, glang11082 said: Thanks Guess I have a brain freeze forgot about the fuses in the 12 Volt closet. Missing the 12 Volt . Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted November 11, 2022 Share Posted November 11, 2022 There are 2 blue wires coming from the furnace. Cut them and attach the side that comes to the furnace to a manual thermostat. Mount the thermostat to the wall above the furnace. The side of the wall facing the interior of the coach. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted November 11, 2022 Share Posted November 11, 2022 All it takes from the blue wires is a contact closure to start the furnace The thermostat will do the rest. Link to comment Share on other sites More sharing options...
