Bandit411 Posted February 8 Share Posted February 8 I have a 2006 Monaco Dynasty Diamond that on our last trip the turn signals and hazard lights quit working. Doe anyone know where the fuse or what supplies the power to the switch. I have been testing wire in the front electrical box and all fuses that I can find in the font box and the box in the engine compartment. if anyone has had this problem and would give me a direction to go to solve this problem I would appreciate it. Link to comment Share on other sites More sharing options...
bgfleck Posted February 8 Share Posted February 8 Not sure if this will help. 2007 Sig wiring diagram Turnsignal.docx Link to comment Share on other sites More sharing options...
Tom Cherry Posted February 8 Share Posted February 8 43 minutes ago, bgfleck said: Not sure if this will help. 2007 Sig wiring diagram Turnsignal.docx 321.88 kB · 3 downloads I printed this in a PDF so you can zoom in on it. Look in the upper right corner. There is a 15 Amp fuse....plus THE HAZARD FLASHER. If good fuse....pull the flasher and get a new one. Past that....it may be tough to troubleshoot....as the Dynasty is not a simple system... Good Luck 2007 Dynasty and UP Turn Signal Wiring.pdf 1 Link to comment Share on other sites More sharing options...
Bandit411 Posted February 9 Author Share Posted February 9 Thanks I’ll see if I can find some relief with the drawing tomorrow morning. I’ll let you know. Link to comment Share on other sites More sharing options...
k7jv Posted February 9 Share Posted February 9 Here are two drawings that might help. One is from Monaco and it is 2006 Dynasty specific. There are coach to coach differences, but it will probably do the trick for you. The other is a drawing that I made that just applied to the brake lighting, primarily. But the left edge "touches on" the turn and tail circuit. Good luck to you!! Schematic - Brake Lights.pdf Schematic - Lights, Turn Signals copy.pdf Link to comment Share on other sites More sharing options...
Twomed Posted February 9 Share Posted February 9 Try the simple stuff first. The flasher relay is mounted on the right hand side of the FRB looking in. It vibrates loose and needs to be pushed down into the socket. Secure it with a wire tie around the relay. Hope it is that easy for you, but I have "fixed" this issue on at least four '06 Dynastys after finding it on mine years ago. Good Luck Try the simple stuff first. The flasher relay is mounted on the right hand side of the FRB looking in. It vibrates loose and needs to be pushed down into the socket. Secure it with a wire tie around the relay. Hope it is that easy for you, but I have "fixed" this issue on at least four '06 Dynastys after finding it on mine years ago. Good Luck Link to comment Share on other sites More sharing options...
WCourand Posted February 10 Share Posted February 10 We had a similar problem a few years back. Turn signals would start to not work and then work. The signals finally stopped working completely. Napa Auto had a replacement flasher and that fixed the problem. Our coach had the flasher in the Left front electrical panel/box / bay just in front of the drivers front tire. I attached a photo of our flasher Link to comment Share on other sites More sharing options...
Bandit411 Posted February 23 Author Share Posted February 23 Thanks for all the input on the turn signal problem. It was a blown fuse that for some reason I kept overlooking. I will not ever forget where that fuse is again. Link to comment Share on other sites More sharing options...
