rschley Posted March 9, 2023 Share Posted March 9, 2023 While turning on the fluorescent lights under the counter, all the gallery lights and back lighting on the switch panel went out. Appears to be a fuse, but checked the fuses. #2 is the Gallery Lights and light rope and the fuse was not blown and tested it with a meter and it shows current through the connection. Is there a fuse I am not finding? I checked all the fuses in the box in the closet and all OK. Is it possibly in the switch? Any ideas or input would be appreciated. Thanks!! Link to comment Share on other sites More sharing options...
Jonbrooks Posted March 10, 2023 Share Posted March 10, 2023 (edited) I have had the switches go bad resulting in loss of fixtures. Have you tested continuity across the switch? Edited March 10, 2023 by Jonbrooks typo Link to comment Share on other sites More sharing options...
Solution rschley Posted March 26, 2023 Author Solution Share Posted March 26, 2023 I tested. Found the rope Light Switch to be bad. Thanks for the tip. I will have to replace. I think that I found one at the original manufacturer. Link to comment Share on other sites More sharing options...
vito.a Posted March 31, 2023 Share Posted March 31, 2023 I've replaced a couple of the factory rope lights with newer LED light strings. I found the LED light strings on Amazon. Less expensive and more reliable than the originals. Link to comment Share on other sites More sharing options...
