4rickyg Posted March 14 Share Posted March 14 Hello group, 05 Navigator. Found my turn signals and flashers not working. Left my flashers on for about 45 minutes when I was unloading the coach. When I went to leave a few days later I found I had no flashes or turned signals. Can't find a bad fuse in the FRB. I do hear the flasher relay clicking. Any ideas? Thanks for your help like always Link to comment Share on other sites More sharing options...
Ivylog Posted March 14 Share Posted March 14 Both front and rear? Link to comment Share on other sites More sharing options...
4rickyg Posted March 14 Author Share Posted March 14 Nothing working. Not front, rear or arrows on mirrors Link to comment Share on other sites More sharing options...
Gary_Curtis Posted March 14 Share Posted March 14 I had a similar problem....turned out to be the hazzard switch. Found the replacement unit on eBay. Link to comment Share on other sites More sharing options...
Martinvz Posted March 14 Share Posted March 14 (edited) Either the switch or the flasher relay. Check the relay as that is the the culprit that we had. $12 part. Edited March 14 by Martinvz Link to comment Share on other sites More sharing options...
Ivan K Posted March 14 Share Posted March 14 If your flasher is a simple 2 wire piece and you hear and feel it click, it looks to be OK but if it is an actual relay, it certainly could be bad even if you hear it. Link to comment Share on other sites More sharing options...
4rickyg Posted March 14 Author Share Posted March 14 There is an actual relay. I pulled it out and reinserted it, no different. I will try picking up a new one. Link to comment Share on other sites More sharing options...
Ivylog Posted March 15 Share Posted March 15 I would start at the steering column switches. Link to comment Share on other sites More sharing options...
4rickyg Posted March 19 Author Share Posted March 19 I bought a new flasher relay at Napa. Everything is working again. Thanks for the suggestions. Link to comment Share on other sites More sharing options...
