Keamyinc Posted April 15, 2023 Share Posted April 15, 2023 Does anyone know where the a/c receiver drier is located on a 2002 Windsor and what the part number of it is? Thanks Don Link to comment Share on other sites More sharing options...
Solution tmw188 Posted April 15, 2023 Solution Share Posted April 15, 2023 Try looking underneath just above the rear axle I believe it’s in that area. Link to comment Share on other sites More sharing options...
Robert U Posted April 15, 2023 Share Posted April 15, 2023 Are you looking for the air dryer for th3 air system (air bags, breakes, etc ) or are you talking about A/C for dash ? Link to comment Share on other sites More sharing options...
Keamyinc Posted April 15, 2023 Author Share Posted April 15, 2023 Thank you, found it above the transmission. Link to comment Share on other sites More sharing options...
Dr4Film Posted April 16, 2023 Share Posted April 16, 2023 When I had the Windsor, I changed out the A/C dryer from the bedroom using the small engine/transmission hatch located on the step in front of the closet. I also removed the screws that hold the plate in place that has a bunch of relays mounted to it. The dyer is directly under that plate. Link to comment Share on other sites More sharing options...
