rtmurley Posted June 9, 2020 Share Posted June 9, 2020 My entry door dead bolt lock is binding up and no amount of lubrication will get it working smoothly. Does anyone no the supplier of the dead bolt mechanism (lock) and possible part number? 2009 Monaco Dynasty Ray Murley Link to comment Share on other sites More sharing options...
Guest Posted June 9, 2020 Share Posted June 9, 2020 Hi Ray I have from my 09 Camelot several parts, when you need something from this pictures I can sell to you. Please email my at vilsis (at) vilsis (dot) net. Ray Vils Link to comment Share on other sites More sharing options...
HStoterau Posted June 10, 2020 Share Posted June 10, 2020 Hi Ray I just repaired the deadbolt on my 1995 Executive. I was able to make some parts from a couple of Schlage locks work in my old lock. It appears that most, if not all, of the deadbolts on Monaco units were supplied by Schlage. I think that all of the deadbolts were the same at least on the pre 2008 units. I found some of them in a Google search for" Monaco rv deadbolt lock". There are a lot of responses. When I was looking I found one that advertised "Monaco Deadbolts". It was more expensive than most of the locks I found. However, it might have fit better. Good luck!!!! HStoterau Link to comment Share on other sites More sharing options...
veraken Posted June 10, 2020 Share Posted June 10, 2020 (edited) Here are 2 files that may help you adjust your lock Door Adjustment - Entrance.pdf Door Bushing Replacement & Latch Adjustment.pdf Edited June 10, 2020 by veraken correction Link to comment Share on other sites More sharing options...
Guest Posted June 10, 2020 Share Posted June 10, 2020 All parts on the photo are sold to rtmurley Link to comment Share on other sites More sharing options...
woodylmiller Posted June 12, 2020 Share Posted June 12, 2020 Mine had some issues but it was just a problem with the strike plate being beat up from the bolt being extended at times when shutting the door that bent the plate. After fixing the bent plate I've had no issues, not sure if that's your issue or something in the lock itself. Roadmiester 09 Dynasty Regal IV Link to comment Share on other sites More sharing options...
Guest Tim503 Posted June 12, 2020 Share Posted June 12, 2020 I've been looking for the inside plate which is about 4 x 3 with a hole in it. The problem with these is they broke the side window and turned the lock from the inside. I'm going to double key the lock even though i know it could make a death trap if the key is not in the lock. I need the upper linkage for the hold open feature. My father shoved the door closed when he checked it after the break in and saw the door stuck open. He then called me and said he got the door closed and how hard it was to close. Bent the hell out of the linkage. Thanks Dad. Link to comment Share on other sites More sharing options...
rtmurley Posted June 16, 2020 Author Share Posted June 16, 2020 Dead bolt lock update I replaced the dead bolt lock with a new one purchased from Rainer Vilsis and all is well. Someone posted that they were going to replace their dead bolt with a double keyed one (keyed inside and out). PLEASE DON’T DO THIS. If you have seen videos of how quickly a motor home fire spreads you won’t have time to fumble with a key to get out. You can’t have anything so valuable in your coach worth risking your life. Ray Murley 2009 Dunasty Link to comment Share on other sites More sharing options...
Guest Tim503 Posted June 17, 2020 Share Posted June 17, 2020 10 hours ago, rtmurley said: Dead bolt lock update I replaced the dead bolt lock with a new one purchased from Rainer Vilsis and all is well. Someone posted that they were going to replace their dead bolt with a double keyed one (keyed inside and out). PLEASE DON’T DO THIS. If you have seen videos of how quickly a motor home fire spreads you won’t have time to fumble with a key to get out. You can’t have anything so valuable in your coach worth risking your life. Ray Murley 2009 Dunasty You do know that the bedroom window is a fire escape. If you ever have someone break the passenger window to reach in and open the door you will realize the futility and false sense of security you have with your deadbolt. It would be nice if people on here were not so judgemental. I'm capable of staying alive. Do I need to prove it? I want to remind you that if I'm in the motorhome I can leave the key in the lock but when I am away then it will prevent the theif from exiting through the door. Do you want to discus guns now? I don't use them. I can imagine what you would say if I change my windows to unbreakable glass and put a solid door on my bedroom as a safe room. Link to comment Share on other sites More sharing options...
Chargerman Posted June 17, 2020 Share Posted June 17, 2020 (edited) Oh boy. Double keyed deadbolt doesn’t sound like a sound plan. If you have that much trouble/concern with break-ins maybe a different choice of places to stay is in order. Edited June 19, 2020 by Chargerman Link to comment Share on other sites More sharing options...
Ernest Tumbleston Posted June 18, 2020 Share Posted June 18, 2020 My oh my! Link to comment Share on other sites More sharing options...
Just Jim Posted June 24, 2020 Share Posted June 24, 2020 I have a 95 dynasty and I am the only one that can open the door from the outside. Its a technique of pulling the handle and also pulling on the door at just the right time for it to open. The door opens easily from the inside. From the outside, lots of people pull on the handle and just assume its locked because it does not seem to activate the latch. Anyone have any idea what might be wrong with it? Also, the two PDF files in the post up above look very similar to mine. Any idea if they are the same for my year model? Thanks in advance, Jim Link to comment Share on other sites More sharing options...
rtmurley Posted June 25, 2020 Author Share Posted June 25, 2020 Jim Bob, Veraken has posted two files that might help with your door issue: "Door Adjustment-Entrance" and "Door Bushing Replacement and Latch". Your door maybe out of adjustment causing your issues. Ray Murley 2009 Dynasty Link to comment Share on other sites More sharing options...
isptbart Posted July 11, 2020 Share Posted July 11, 2020 Ray - I fought this opening the door problem from the outside until it got to the point I couldn't routinely open the door for my wife. I had previously lubed, adjusted, tech adjusted, etc. I finally took the door apart & found the latching bushing had completely worn out & was now AWOL! I mostly followed the advice of the "Door Bushing Replacement & Latch file "Before" the ACE Hardware bushing revision was added, I ended up turning my own bushing & now anyone can easily open the door unless it is locked! My wife is so happy! (Me Too!). Just a little time consuming, but not a difficult project. Be sure to have a person help you with the door window, as purchasing a replacement for that is expensive in comparison to a small bushing. Wish I had attempted to tackled the project months ago! Bart from VA 07 HR 42 PLQ Link to comment Share on other sites More sharing options...
