Sealand toilet
Need to replace my ball valve seal. 05 Navigator. dometic Model number 3010. Electronic toilet. Does anyone know the model number for the seal and best place to get it?thank you.
I've tried cleaning it and plumber's grease,but it doesn't last very long.
Go to this thread. Your original “file briefcase” which you HOPEFULLY have should have the manual for the toilet.  If not, Google one.
Read the above post. It has comments….The install manual has a part’s breakdown with a Dometic number.  Then Amazon usually has them.  There is an O-ring and ball kit.  Get the whole assembly with the ball.  Typically, the Dometic kits come with the new gas seal that holds it to the floor. Don’t know if you have the wand spray but if you do, get that one.  They may have come with or without…
that’s it
  • Thanks 1
