tmw188 Posted June 3, 2023 Author Share Posted June 3, 2023 Good product page. I choose the Compleat OAT it was readily available at a local Peterbilt dealer in the 50/50 formulation. $16.67 gal 1 Link to comment Share on other sites More sharing options...
rustykramermetalfab Posted June 3, 2023 Share Posted June 3, 2023 Has anyone found an online/youtube video of the detail of how to properly flush a coach coolant system in a coach? I have read a lot but just not sure I fully understand how it is being done. I am to dumb to understand what I read, I need to see it. Link to comment Share on other sites More sharing options...
tmw188 Posted June 3, 2023 Author Share Posted June 3, 2023 You might check this video out. He has a lot of good videos mostly on Cat engines but has many that is just diesel specific in understanding a lot of things. 2 Link to comment Share on other sites More sharing options...
jacwjames Posted June 3, 2023 Share Posted June 3, 2023 When I was thinking about doing a coolant change back in 2015 I did't have a good place to do it (slopped driveway) and the thought of handling ~50 gallons of a mix of old coolant and flush didn't appeal to me. I did get a quote from Cummins $650, but the shop manager suggested I get an analysis done, which I did and it turned out great, no need for a change. But ~3 months later road debris took out my radiator and I ended up getting it replaced under insurance claim. Link to comment Share on other sites More sharing options...
birdshill123 Posted June 4, 2023 Share Posted June 4, 2023 I have used final change in all my motorhomes. Meets every mfrs. requirements. Available in most truck stops and even some Walmarts. Napa as well. O use an inexpensive refractometer from Amazon to test. I drained the old coolant into a bucket and poured into old gallon oil jugs. To refill I drop a 120 volt utility pump into a 5 gallon pail. Pour in coolant. Utility pumps have a garden hose outlet. No pouring into the rad resevoir required. Link to comment Share on other sites More sharing options...
TLMonaco Posted June 5, 2023 Share Posted June 5, 2023 So what is the procedure to purge the air from the cooling system? Thanks Tom Link to comment Share on other sites More sharing options...
rustykramermetalfab Posted June 5, 2023 Share Posted June 5, 2023 1 hour ago, TLMonaco said: So what is the procedure to purge the air from the cooling system? Thanks Tom If you watch the video the tech uses a system called Airlift. Slick deal. If you do your own coolant change out its paid for. I just ordered one from Ebay for $110.00 Link to comment Share on other sites More sharing options...
Yoaks5 Posted June 5, 2023 Share Posted June 5, 2023 12 hours ago, TLMonaco said: So what is the procedure to purge the air from the cooling system? Thanks Tom All systems are different but my overflow tank is the highest point in my system and I've changed mine 3 times now with no air trapped. I also used peak final charge. 1 Link to comment Share on other sites More sharing options...
