sg47619 Posted June 15, 2023 Share Posted June 15, 2023 I think I know the answer but why would there be water leaking out of the aqua hot system where the exhaust pipe comes out. We we’re leaving on a short trip Sunday Link to comment Share on other sites More sharing options...
willbo777 Posted June 15, 2023 Share Posted June 15, 2023 Take the cover off and be sure you don't have a fitting leaking. The hole where the exhaust comes out is at the bottom and where any leakage ends up. Keep your fingers crossed that is what it is. Link to comment Share on other sites More sharing options...
sg47619 Posted June 15, 2023 Author Share Posted June 15, 2023 Getting ready to take it apart now, we shall see. Link to comment Share on other sites More sharing options...
sg47619 Posted June 15, 2023 Author Share Posted June 15, 2023 3 hours ago, willbo777 said: Take the cover off and be sure you don't have a fitting leaking. The hole where the exhaust comes out is at the bottom and where any leakage ends up. Keep your fingers crossed that is what it is. Took the cover off can’t see any hose’s or valves leaking there is some water coming from the inspection plate where the heater element goes in. Link to comment Share on other sites More sharing options...
Dr4Film Posted June 15, 2023 Share Posted June 15, 2023 Not good news. You most likely have an older Aqua-Hot with the internal fresh water coil inside the boiler which has sprung a leak. Link to comment Share on other sites More sharing options...
sg47619 Posted June 15, 2023 Author Share Posted June 15, 2023 1 hour ago, Dr4Film said: Not good news. You most likely have an older Aqua-Hot with the internal fresh water coil inside the boiler which has sprung a leak. Yes it’s a 100-00S model that sets in the moof the basement, I have a quote of 11.6 for the new 600 model and that’s not installed Just now, sg47619 said: Yes it’s a 100-00S model that sets in the moof the basement, I have a quote of 11.6 for the new 600 model and that’s not installed Middle not moof 🤦🏻♂️🤣 Link to comment Share on other sites More sharing options...
96 EVO Posted June 15, 2023 Share Posted June 15, 2023 1 hour ago, sg47619 said: Took the cover off can’t see any hose’s or valves leaking there is some water coming from the inspection plate where the heater element goes in. Bottom insulation may be saturated and some water escaping there. Link to comment Share on other sites More sharing options...
sg47619 Posted June 15, 2023 Author Share Posted June 15, 2023 37 minutes ago, 96 EVO said: Bottom insulation may be saturated and some water escaping there. Ok thanks Link to comment Share on other sites More sharing options...
willbo777 Posted June 16, 2023 Share Posted June 16, 2023 20 hours ago, sg47619 said: Took the cover off can’t see any hose’s or valves leaking there is some water coming from the inspection plate where the heater element goes in. Pull the inspection plate off and see where the leaking is coming from, don't give up on it yet. Link to comment Share on other sites More sharing options...
Raymond Posted June 16, 2023 Share Posted June 16, 2023 Had the same issue two weeks ago—domestic water fittings loose. Take you time and look carefully and tighten fittings as you go. Link to comment Share on other sites More sharing options...
djlgnd Posted June 17, 2023 Share Posted June 17, 2023 haveing issue taking the cover off my 100-01s in my 2003 camelot, Help Please as i think i got all rivets out, are there rivets at the very back of the unit. Yes i have a water leak. Link to comment Share on other sites More sharing options...
