Guest Ray Davis Posted July 13, 2023 Share Posted July 13, 2023 If you have an Ambassador you probably should read this thread over on IRV2 https://www.irv2.com/forums/f115/slide-openings-out-of-square-618789.html Link to comment Share on other sites More sharing options...
jacwjames Posted July 13, 2023 Share Posted July 13, 2023 Wow, another frame problem. I posted about a crack I found when I was doing my maintenance/inspection. Not nearly as bad but I caught it early, I've seen much worse. It pays to take the time to look. In my case a ~1 hour repair, I spent 45 minutes prepping and it took my neighbor 15 minutes to weld. Link to comment Share on other sites More sharing options...
Solution Gary 05 AMB DST Posted July 13, 2023 Solution Share Posted July 13, 2023 This only applies up to the 2004 and earlier frames. The Ambassador went on the Endeaver platform in 2005. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
TomV48 Posted July 13, 2023 Share Posted July 13, 2023 58 minutes ago, Gary 05 AMB DST said: This only applies up to the 2004 and earlier frames. The Ambassador went on the Endeaver platform in 2005. Gary 05 AMB DST Wow Gary, I hope you are correct. This was scary reading until I saw your post!👍 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted July 14, 2023 Share Posted July 14, 2023 5 hours ago, TomV48 said: Wow Gary, I hope you are correct. This was scary reading until I saw your post!👍 Tom, I'm correct. I was scared too till I saw the year. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
throgmartin Posted July 15, 2023 Share Posted July 15, 2023 On 7/13/2023 at 6:36 PM, TomV48 said: Wow Gary, I hope you are correct. This was scary reading until I saw your post!👍 Tom: Gary is correct. 2005 was a major upgrade tear for the Ambassador/Knight. It went to the RR8R chassis as well as numerous other upgrades. The 2004 and 2005 Ambassador/Knight's are totally different animals. 1 Link to comment Share on other sites More sharing options...
Agpopp Posted July 26, 2023 Share Posted July 26, 2023 Is this a Neptune / Cayman issue possibility? That's a terrible situation to be in and I'd like to avoid it! Link to comment Share on other sites More sharing options...
