Romeo84 Posted August 8, 2023 Share Posted August 8, 2023 Hey guys I had my flex pipe under the motor between the muffler and the downpipe fall off on my drive home this weekend. Seems like it's a pretty standard part but if any one has a part number that would be cool. Real reason for the post is Does anyone have a picture of their rig with a straight pipe. After hearing her roar Like that, I kind of want to put a straight pipe on It. Looking for pictures and parts they used. 2001 sig ism . Thanks in advance Link to comment Share on other sites More sharing options...
WayneC Posted August 8, 2023 Share Posted August 8, 2023 Morning I just replaced mine,it is just a standard flex pipe from the truck shop,I rerouted it under the oil pan,put a new crome tip on and that is it,plenty of noise with standard muffler. Wayne 1999 signature ceaser 1 Link to comment Share on other sites More sharing options...
Mike Wahl Posted August 8, 2023 Share Posted August 8, 2023 There was a post someone on this topic in the last couple of years. I was looking at it for my 2001 Signature. I had other things more pressing at the time, however was thinking in the future I would need to address this issue also. It was a good post with options for mufflers and videos of the sound. I have searched and can't find it. I was thinking it was on here or IRV2. Anyone remember this. Link to comment Share on other sites More sharing options...
Bliksem Posted August 8, 2023 Share Posted August 8, 2023 I installed an MBRP 2220s, sound clip at idel. pipe.MOV 1 Link to comment Share on other sites More sharing options...
Solution DavidL Posted August 8, 2023 Solution Share Posted August 8, 2023 This is the muffler I put on my ISM500 https://www.amazon.com/Aero-Exhaust-Performance-Muffler-AT5050XL/dp/B07HZ3NVBX I would also post an audio clip, but it sounds very much like Bliksem's...maybe a very small touch less muffled. Where it sound neat (and the only time I hear it in the driver's seat) is going up Vail Pass thru the tunnel and floor it 🙂 It is straightforward plumbing job. Just measure your sizes, get pipe / adapter / clamps to match, get some quality hangers, ensure you are connecting to something solid, put some rubber isolators in the strap and go for a drive. 1 1 Link to comment Share on other sites More sharing options...
Melvin Posted August 9, 2023 Share Posted August 9, 2023 On my 2001 Monaco we found that the exhaust piping needed replacing all the way back to the turbo, a big hole had blown thru the pipe next to the block. Link to comment Share on other sites More sharing options...
Gene Y Posted August 12, 2023 Share Posted August 12, 2023 I removed my muffler (full of holes) and installed a straight exhaust I picked up at a truck repair facility. It was intended to be installed as a straight up exhaust on a semi. Goes from 5" to 7" all chrome and truly straight. Had to build a new support system for it and ran it straight out the back. Had to modify the fiberglass where it exits from under the rig. Saw the same exhaust at a chrome shop on I-40 in Texas last year. Has a beveled tip, looks and sounds awesome! It's a little dirty right now. On a trip for the past 2 months! 1 Link to comment Share on other sites More sharing options...
