hex_nut Posted August 14, 2023 Share Posted August 14, 2023 The circuit breaker on my QD8000 is starting to fail (after 17 years, I am not surprised). Does anyone have experience in replacing this circuit breaker and can tell me how deep I will have to go in disassembling the unit in order to replace the breaker? Thanks Richard Link to comment Share on other sites More sharing options...
Frank Bergamo Posted August 14, 2023 Share Posted August 14, 2023 I replaced one on a 10K a while back and it was not very difficult at all. If the panel it is mounted in is accessible, then should be no problem at all. A few screws holding it to the panel and a few terminal screws and that is about it. Fairly straightforward and not very difficult. Hope this helps. 1 Link to comment Share on other sites More sharing options...
Ivan K Posted August 15, 2023 Share Posted August 15, 2023 On mine I would have to swing the coolant reservoir out of the way which only takes 2 or 3 bolts on top and then I can pull the dual breaker into the side service opening from behind the panel. The same I do to change the air filter, if due. 1 Link to comment Share on other sites More sharing options...
Solution hex_nut Posted August 17, 2023 Author Solution Share Posted August 17, 2023 Ivan and Frank Thank you for your insight. My 8K is obviously built different than your 10K. I had to remove the entire top (about a dozen hard to get to bolts). Then I could move the coolant surge tank out of the way and get to the circuit breaker. After installing the new breaker, everything works correctly under load. Yipee! If anyone is in need of the 35 amp double pole breaker that Onan used on the 7.5 and 8K units, I found it available on Amazon from the OEM manufacturer (AIRPAX, IEG66-28333-2-V) at about 2/3 the cost of the Cummins part #. https://www.amazon.com/dp/B07KW6N539?psc=1&ref=ppx_yo2ov_dt_b_product_details Richard Just a p.s. My circuit breaker was not tripping, but any load over about 20 amps would cause the breaker to lose voltage below the minimum required to keep the ATS contactor energized. I initially thought my ATS was failing, but after much testing, determined it had to be the generator dropping voltage. Richard 2 Link to comment Share on other sites More sharing options...
