Tony G. Posted September 7 Share Posted September 7 I am looking for a way to remove this trim without destroying it. Anyone with any experience with this? Any help would be appreciated. Tony 1998 Dynasty Link to comment Share on other sites More sharing options...
Tom Cherry Posted September 7 Share Posted September 7 Perhaps a description of the location or a second or third photo with more definitive shots of the surrounding area might help.... Good Luck...lots of folks know things that many supposed experts don't on doing trim repairs and such... Link to comment Share on other sites More sharing options...
Rick A Posted September 7 Share Posted September 7 Those buttons just pop off (there’s a tool for this) but you can also carefully prize them of without damaging them. Just now, Rick A said: Those buttons just pop off (there’s a tool for this) but you can also carefully prize them of without damaging them. Use a blunt knife or a pry tool. Underneath you will find screws. Trim around the front door? Link to comment Share on other sites More sharing options...
Tony G. Posted September 8 Author Share Posted September 8 Yes, I took the screws out that are underneath the caps. But the trim is still held on firmly This is the trim attached to th pillar between the door (on the right in the picture) and the window. I am guessing it hides whatever the front cap attaches to. Link to comment Share on other sites More sharing options...
windsorbill06 Posted September 8 Share Posted September 8 1 hour ago, Tony G. said: Yes, I took the screws out that are underneath the caps. But the trim is still held on firmly This is the trim attached to th pillar between the door (on the right in the picture) and the window. I am guessing it hides whatever the front cap attaches to. did you already take the trim around the door off? With the screw buttons showing in the last picture? Then the hard plastic cover will be fully visible. There may be more screws in the hard plastic, under the door trim. Link to comment Share on other sites More sharing options...
Tony G. Posted September 8 Author Share Posted September 8 Yes I pulled the door trim back but there are no exposed screws holding the trim down Link to comment Share on other sites More sharing options...
Cubflyer Posted September 8 Share Posted September 8 If you removed the caps and then the screws under the caps, someone has glued that trim so you could try a putty knife under it to get it loose Link to comment Share on other sites More sharing options...
windsorbill06 Posted September 8 Share Posted September 8 (edited) 27 minutes ago, Tony G. said: Yes I pulled the door trim back but there are no exposed screws holding the trim down gently pry it off. There may be double sided tape, silicone, or who know what. I start at the top, with the smaller trim piece that butts to the ceiling. Once you pry the long piece away from the wall, you need to work it up as it's usually between the dash, wall and windshield gasket pretty tight.. Slow and steady. it is somewhat flexible, but I wouldn't bend it too much. When you put it back together, there is no reason to use anything but the screws--at least I never did. Edited September 8 by windsorbill06 Link to comment Share on other sites More sharing options...
Les Hurdle Posted October 19 Share Posted October 19 I'm no doubt doing this wrong but figured I'd tag onto this topic as my issue is sim. Wife was putting slide out and 'forgot' ! Result is the end trim is now partway off. Hope the pic tells the tale. I suspect the screws are under the fabric. I'd prefer not to take the whole thing off..... how does one remove the fabric? Link to comment Share on other sites More sharing options...
