thompson_skip Posted September 10 Share Posted September 10 Pulling into Augusta, MT, we smelled fuel and we were lucky that this happened as we were pulling into town, as the roads were narrow with barely a shoulder. There was a campground at the edge of Augusta in front of which we parked for the day! We found the fuel leak. Fortune led me to call a mobile repair guy in Great Falls MT. Karl’s business is Diesel Fever, phone 406-781-6898 and I recommend him to the sky! It was 6pm when he arrived and by 8 we were back on the road to Helena! I pulled the headlights switch and had headlights, but no taillights or marker lights. Any ideas on getting taillights and marker lights working? Thanks 2003 Monanco Dynasty Link to comment Share on other sites More sharing options...
timaz996 Posted September 10 Share Posted September 10 Check your VIP smart wheel connections in your driver's side electrical bay for any burnt wires. Here is their trouble shooting doc and wiring diagrams. SmartWheel TROUBLESHOOT.pdf Link to comment Share on other sites More sharing options...
Robert92867 Posted September 11 Share Posted September 11 From what I can see in your pics... you run a clean machine, which undoubtably assisted your mobile mechanic in pinpointing the problem. Nice work! Link to comment Share on other sites More sharing options...
thompson_skip Posted September 24 Author Share Posted September 24 It did check the wires going into the smart wheel control box and they are good. A number of years ago I replaced the wires going into the smart wheel control box with larger gauge wire as the wires that Monaco used were not large enough to carry the current and they melted the plug. Still don’t have taillights. Still on the road traveling only in day time. When I get home I will figure out what is going on. Thanks Link to comment Share on other sites More sharing options...
thompson_skip Posted November 22 Author Share Posted November 22 I have been having an issue with my pull out light switch for some time. When I pull it on at times I need to wiggle the pull out stem to get headlights to turn on. I’m wondering if the switch could also be to cause of my lack of taillights and marker lights. I’m thinking I need to replace the pull out switch. Can anyone tell me the part umber and where I can get a new headlight switch? 2003 Dyansty Link to comment Share on other sites More sharing options...
StephenW Posted November 22 Share Posted November 22 I replaced the headlight switch in my ’01 Dynasty with a 70’s Chevrolet switch from NAPA Auto Parts store. The switch worked fine and was easy to replace. 20% off Eligible Headlight Switch 2.0 (1) Part #: ECH HL6613 Guaranteed to fit your vehicle1978 Chevrolet C10 1/2 Ton - Pickup $39.99 / each Link to comment Share on other sites More sharing options...
thompson_skip Posted November 22 Author Share Posted November 22 Thanks for the info Stephen. When you removed the switch does it come out the bottom of the dash or did you take it out of the access hole on the dash? Any advice on getting old one out would be much appreciated. Link to comment Share on other sites More sharing options...
StephenW Posted November 23 Share Posted November 23 IIRC the access panel on top of the dash allows for getting to the switch to push in the button which releases the pull out knob. Then I just took the switch out the top and reversed the operation to install the new one. Link to comment Share on other sites More sharing options...
thompson_skip Posted November 24 Author Share Posted November 24 Ok thanks so much for the information. I discovered that if I push the smart wheel button above the wiper control that all the marker lights and the taillights come on. So I guess that indicates that the smart wheel control box must be ok. I’m hoping that this means that the light switch is the issue. I will go to Napa and try to get new switch. Thanks to all for assistance!!! Link to comment Share on other sites More sharing options...
