hadarrowjr Posted September 11, 2023 Share Posted September 11, 2023 Issue I currently own a 2017 Monaco Diplomat 43D. I wanted to update my flooded batteries to lithium batteries. My Firefly system only allows for Flooded, AGM or AGM-2. I contacted Firefly to see if an update in the software was possible. I was also interested in updating to a larger screen and moving my current controller to the front in the driver’s area. I don’t believe the cost and lead time for this update. Request Price Lead time: 1. Adding Lithium Batteries to your current programming- $1,175.00 24-32 weeks- Must be paid in advance- No cancellation-No refund 2. Changing the current screen to a new colored screen $2,900.00 24-32 weeks- Must be paid in advance- No cancellation-No refund 3. Adding an additional screen at the front of the coach. $2,900.00 24-32 weeks- Must be paid in advance- No cancellation-No refund. Link to comment Share on other sites More sharing options...
vito.a Posted September 11, 2023 Share Posted September 11, 2023 What brand and model inverter do you have? If you have a Magnum inverter, call Magnum Tech support. From memory, the Magnum inverter AGM 2 charge profile can work with lithium batteries with some adjustments. 800-553-6418 You can also check with your lithium battery manufacturer. Battleborn has great tech support. 1 Link to comment Share on other sites More sharing options...
hadarrowjr Posted September 11, 2023 Author Share Posted September 11, 2023 Thank you! I’ll check with them. Link to comment Share on other sites More sharing options...
Ivylog Posted September 11, 2023 Share Posted September 11, 2023 Unless you dry camp often, the AGM2 setting is excellent for Lithium that should be stored at 50-70% SOC. The AGM2 setting won’t start charging until the Lithium gets down to 30% and back up to 99%. Ypu can buy a new Magnum display with Lithium settings for less than $200. If you only dry camp occasional, you can charge Lithiums by forcing a rejuvenation cycle in the LA setting. The BMS in the Lithium will stop the charging when they are 100% SOC. Link to comment Share on other sites More sharing options...
hadarrowjr Posted September 11, 2023 Author Share Posted September 11, 2023 Thank you. My current Firefly management system has settings for the AGM batteries. I’m thinking about upgrading to the AGM batteries. Looking at Lifeline. Link to comment Share on other sites More sharing options...
amphi_sc Posted September 12, 2023 Share Posted September 12, 2023 This Lifeline distributor is close to me so I've picked up batteries directly from them, but they do ship nationwide too. https://centexbatteries.com/ Link to comment Share on other sites More sharing options...
hadarrowjr Posted September 12, 2023 Author Share Posted September 12, 2023 Thank you! I’ll check with them prior to buying. What do you have the low battery shut off set at? Link to comment Share on other sites More sharing options...
