camelot Posted September 20 Share Posted September 20 Got a C1 code and its beeping, seams to be cooling though, Looked up code and it says low voltage. Tried disconnecting power to control board didnt work still beeping. Float charging any ideas?? Link to comment Share on other sites More sharing options...
Dr4Film Posted September 20 Share Posted September 20 Don't see a C1 code in the Norcold 1200 service manual. You didn't post what model Norcold you have so no idea. Link to comment Share on other sites More sharing options...
Solution camelot Posted September 20 Author Solution Share Posted September 20 Sorry Model# 2117lM Link to comment Share on other sites More sharing options...
camelot Posted September 21 Author Share Posted September 21 16 hours ago, camelot said: Sorry Model# 2117lM 16 hours ago, camelot said: Sorry Model# 2117lM Link to comment Share on other sites More sharing options...
camelot Posted September 21 Author Share Posted September 21 17 hours ago, Dr4Film said: Don't see a C1 code in the Norcold 1200 service manual. You didn't post what model Norcold you have so no idea. C1 is in the window of refrig and the beeping is too much! the frig is working amagine that. any help please! TY Steve Link to comment Share on other sites More sharing options...
Ivan K Posted September 21 Share Posted September 21 This is what I saw in 2117 manual online 1 Link to comment Share on other sites More sharing options...
camelot Posted September 21 Author Share Posted September 21 I saw that also, but what does that mean and where is it to check resistance.TY Steve Link to comment Share on other sites More sharing options...
Dr4Film Posted September 21 Share Posted September 21 The thermistor should be located attached to the fins at the top rear of the fridge compartment. Link to comment Share on other sites More sharing options...
camelot Posted September 22 Author Share Posted September 22 On 9/20/2023 at 4:47 PM, Dr4Film said: Don't see a C1 code in the Norcold 1200 service manual. You didn't post what model Norcold you have so no idea. Thank You! Steve Link to comment Share on other sites More sharing options...
camelot Posted October 5 Author Share Posted October 5 Ok the C1 code was a air thermister out of range. It is inside the frig right hand side, replaced it for like 18 dollars, beep went away all is good! TY Steve Link to comment Share on other sites More sharing options...
