LakeBob Posted October 3 Share Posted October 3 Had the oil changed and AC serviced on the rig today. Now I have a Generator Door warning on the dash display. I’ve searched all over the gen compartment without seeing any obvious switch. Anyone familiar with the indicator switch location? Thanks! Link to comment Share on other sites More sharing options...
Ivan K Posted October 3 Share Posted October 3 Maybe technology changed to magnetic or pressure switch or what ever but mine is just a regular pin switch. Simple. Link to comment Share on other sites More sharing options...
jacwjames Posted October 3 Share Posted October 3 1 hour ago, Ivan K said: Maybe technology changed to magnetic or pressure switch or what ever but mine is just a regular pin switch. Simple. Mine is the same, inhibitor switch. But this could be mounted in a different location to sense generator slide is in the stored position Link to comment Share on other sites More sharing options...
LakeBob Posted October 4 Author Share Posted October 4 Found it once I got off the side of the road. Magnetic proximity switch, similar to the door. The wired end is loose in a press fit socket. Will need to apply some silicone. Link to comment Share on other sites More sharing options...
jacwjames Posted October 4 Share Posted October 4 So they changed the type, not sure if that's good or bad. But at least your found it. Link to comment Share on other sites More sharing options...
