Rico K 2005 Knight Posted October 5 Share Posted October 5 Good afternoon everyone. Rico k here requesting some electrical assistance with my dash warning alarm. It starts sounding at 14.1 volts. My gauge and 2 different volt meters are accurate. Is there a sending unit for the warning buzzer that may have gone bad? Link to comment Share on other sites More sharing options...
Ivan K Posted October 5 Share Posted October 5 Does the dash light come on as well with the buzzer? Link to comment Share on other sites More sharing options...
cbr046 Posted October 5 Share Posted October 5 Try swapping relays in the Monaco 2 box in the front run bay under the driver (PacBell 1 & 2). From a shotgun perspective it's easy and quick to do. Took me over a week to find my problem when it would have been 1 minute had I considered a bad relay. The relays in Monaco 1 box are the same type. Horn relay was the least critical for me. - bob Link to comment Share on other sites More sharing options...
Rico K 2005 Knight Posted October 5 Author Share Posted October 5 3 hours ago, Ivan K said: Does the dash light come on as well with the buzzer? Yes it does. 3 hours ago, Ivan K said: Does the dash light come on as well with the buzzer? New at this site so forgive me if I'm sending messages twice. Yes the warning buzzer and dash light come on at the same time. That is how I know it's the alternator as the buzzer is also for most of the other gauges. They will go off if I turn all the lights and heater on causing the voltage to drop below 14.1 2 hours ago, cbr046 said: Try swapping relays in the Monaco 2 box in the front run bay under the driver (PacBell 1 & 2). From a shotgun perspective it's easy and quick to do. Took me over a week to find my problem when it would have been 1 minute had I considered a bad relay. The relays in Monaco 1 box are the same type. Horn relay was the least critical for me. - bob 2 hours ago, cbr046 said: Try swapping relays in the Monaco 2 box in the front run bay under the driver (PacBell 1 & 2). From a shotgun perspective it's easy and quick to do. Took me over a week to find my problem when it would have been 1 minute had I considered a bad relay. The relays in Monaco 1 box are the same type. Horn relay was the least critical for me. - bob I will try that and let you know. Thank you. Link to comment Share on other sites More sharing options...
Ivan K Posted October 5 Share Posted October 5 6 minutes ago, MONACOKNIGHT said: Yes it does. In that case, if you have solar charging or generator running along with the alternator, it seems to not be an unusual situation with competing charging power sources. The fact that your light is combined with a buzzer may be a bit out of norm, don't know, mine isn't. People solve it by turning headlight on and not worry. Link to comment Share on other sites More sharing options...
Rico K 2005 Knight Posted October 5 Author Share Posted October 5 Ok. That may answer my question then. I do have solar panels and definitely if I have the engine running while plugged in is when it does it most. I just thought that 14.2 like in most vehicles was normal. My alternator is mostly mid to high 13s. Link to comment Share on other sites More sharing options...
Rico K 2005 Knight Posted October 19 Author Share Posted October 19 On 10/5/2023 at 1:35 PM, Ivan K said: Does the dash light come on as well with the buzzer? It did as well. I found it only did it when plugged into shore power and fooling the warning system that it was over charging. All good now. Thanks 😊 Link to comment Share on other sites More sharing options...
