Air Dryer Inop?
Go to solution Solved by 96 EVO,
Have noticed lately that my air dryer is not purging as it has in the past. I have listened for it as the compressor reaches operating pressure, nothing.  Also have used an aux compressor to fill the system to 120 PSI, still nothing. Yes, the filters have not been changed in maybe three years. Could the pop-off valve be stuck? Could the filters be so clogged that it can cause it not to release?
Jim Eastburn
2000 Signature
Good morning, thanks Ben, I use the aux compressor to air up when I'm leaving the campsite early in the morning so as not to wake anyone. But even using the engine compressor the air dryer will not purge.
Jim
2000 Signature
  • Solution
Hmmm.
So your governor is unloading your compressor, just no purge.
You may be better off just replacing the dryer assembly. They do tend to fail after a while, and replacing them isn't much more than buying the rebuild kits.
  • Like 2
Went through this last year. The purge valve in the air dryer was old dirty and not sealing so it never fully seated.
You can get a new purge valve kit for cheap it doesn't come with the slide valve though. I bought a new air dryer off Amazon that was defective so don't do that. If the needle stops building its in the dryer.
  • Like 2
1 minute ago, engine103 said:
It might be easier to rebuild than it was to find it!
Ha!
Yeah, in those days they mounted them in a gawdawfull place for an RV!
Fine for a semi where they were easily accessible with no trailer!
Paul, that may be true. Draining the holding tanks revealed no moisture or oily substance so I think I'm good there. But, your right, I'm not going anywhere for a while and plans are to replace it. Thanks, Jim
On 10/13/2023 at 1:23 PM, Jdw12345 said:
I would check the air governor for proper operation.
I would replace the purge valve next, jmo.
 This might help.
https://www.wabco-customercentre.com/catalog/docs/mm34_web.pdf
jdw12345, thanks for the link, going into my file! Jim
