rccook Posted October 14 Share Posted October 14 97 Windsor furnace will not start blower. Has 4 button control and runs heat strips in both AC . When switched to furnace mode the fan symbol is missing on board. Propane works fine on stove and fridge. Unit is below fridge. Should I remove unit and take to dealer? Link to comment Share on other sites More sharing options...
tmw188 Posted October 14 Share Posted October 14 Try asking Google and YouTube and pick out the more professionally feeling video and you’ll probably be able to determine your issue. Check back. Link to comment Share on other sites More sharing options...
pulsarjab Posted October 15 Share Posted October 15 Has the furnace ever worked, with the AC heat strips? Link to comment Share on other sites More sharing options...
rccook Posted October 16 Author Share Posted October 16 Not at same time. T-stat will run heat strips is what I meant. Have pulled furnace and checked sail, high temp switches. Got it to run blower but when I moved unit the case sparked against gas line. Propane shut off and plugged. Got a short somewhere. Taking to repair shop. Link to comment Share on other sites More sharing options...
Tom Cherry Posted October 16 Share Posted October 16 I suspect that you have an earlier version of the thermostats that most of us have. We have a 5 or now 10 system. These are multiplexed and the only thing that the thermostat does is “tell the furnace” to start. No interconnecting wiring, other than an on/off switch. I don’t know exactly how the 4 button worked…fully understand the 5…..and can assist and troubleshoot…...but we have had issues with the 4 button…. Here is a topic that you might want to read to get some info, if it IS the Thermostat….or if you have issues with the Thermostat in the future….not many options…. Link to comment Share on other sites More sharing options...
Mark Underhill Posted October 18 Share Posted October 18 I added a separate thermostat to mine so I can run the furnace at same time as the heat strips. Really helps, run the heat strips with fan on low and it circulates the air keeping coach nicely warmed. Its easy to do and I love it set up that way should have been that way from the factory IMO. Link to comment Share on other sites More sharing options...
