Water Sensor Location? 1999 Dynasty. Thanks
Your 99 Dynasty that 8.3 is a CAPS fuel injection, right?  If so it's on the bottom of the secondary fuel filter (shown above).  Secondary fuel filter is just rearward of the starter.
- bob
  • Tom Cherry changed the title to Water Sensor Location? 1999 Dynasty. Thanks
38 minutes ago, Glenn Duggan said:
Thanks guys, but its not on the filter. I will keep looking!
If it's not on the bottom of one of your fuel filters, someone has installed the wrong filter.
Some water separating filters use a clear plastic bowl on the bottom, to make it easy to see if there is water in there.
{edit} I see Jim W states in his post that his '95 model had a stand alone water separator box. I've never seen one.
Edited by 96 EVO
The picture above is what my fuel filter/water separator looked like.  It had an electric pump that when you pushed the button for 'air' it would prime the air out of the line... for water it would drain it from the bottom of the filter.  It was manufactured by Wynn.
  • Thanks 1
