Richard Tree Posted November 14, 2023 Share Posted November 14, 2023 Has anyone seen a defintion for the species of burl that Monaco was using fo rthe plastic dash and console panels? There are places with used panels but no decription of the "design" An ideas? I'd like to rpalce some of the heat lifting vinyl on the dash and other locations in the coach. Link to comment Share on other sites More sharing options...
Solution JDCrow Posted November 14, 2023 Solution Share Posted November 14, 2023 Looks a lot like walnut burl 1 Link to comment Share on other sites More sharing options...
Paul J A Posted November 15, 2023 Share Posted November 15, 2023 http://www.custominstrumentpanels.com. Link to comment Share on other sites More sharing options...
Richard Tree Posted November 15, 2023 Author Share Posted November 15, 2023 Thanks very much for the input - I have seen other coaches with the sam epanels and walnut is probably the best look. REV was no help "sorry we have no info " response. Even though I provided the Monaco and Mills Mfg part numbers on the inside stickers... Link to comment Share on other sites More sharing options...
Dennis H Posted November 15, 2023 Share Posted November 15, 2023 https://www.nwrvsupply.com/ bought all Monaco parts when they closed the facility in Oregon. They have replacement parts and will look it up for you. If yours are simply broken there's an easy fix for that. IMO, Monaco put the screw holes too close to the edge and they seem to break right there. There's an easy fix for that also. Simply remove the dash piece, get a scrap piece of aluminum and have it water jetted to match then glue them together and reinstall. Here's a pic.... https://executive45pbq.blogspot.com/2020/ the result is a solid piece that will never break......Dennis 1 Link to comment Share on other sites More sharing options...
JDCrow Posted November 16, 2023 Share Posted November 16, 2023 If you can find a Hydro dip biz, they can refinish your panels very easily. https://youtu.be/vb-PH_O7evU?si=hI4zD9wmI6EGDW8q 1 Link to comment Share on other sites More sharing options...
FLynes Posted November 16, 2023 Share Posted November 16, 2023 Hydro dipping is an excellent idea, and make sure they spray a few coats of clear over it, to protect it. That is, unless technology has progressed to the point where the end result lasts longer than it used to. Link to comment Share on other sites More sharing options...
heathbus Posted November 17, 2023 Share Posted November 17, 2023 Bravo burl is what a vendor told me was the burl type. Link to comment Share on other sites More sharing options...
