Robert92867 Posted December 25, 2023 Share Posted December 25, 2023 My first encounter with a difficult Stop Ring was rebuilding my Holset HX35W Turbo. I bent the stop ring trying to force it in and ending up buying another kit. My second encounter with a difficult Stop Ring was yesterday, replacing a chipped pinion Gear on my Delco-Remy MT28 starter. I already replaced the starter (unbranded $120) last year, but could not bring myself to throw away the original Delco-Remy. A year ago I sourced the pinion gear/clutch assembly, and a month ago I sourced the repair kit. Again, it was installing the Stop Ring that gave me trouble. I tried force, ending up bending the ring a little, straightened the ring then tried the method show below in the picture. After maybe 100 tries the Stop Ring popped into the Pinion Stop. Now I have a spare starter, but there MUST be a better way? Link to comment Share on other sites More sharing options...
Dr4Film Posted December 25, 2023 Share Posted December 25, 2023 Don't they make stop-ring pliers that can be used for installation? 1 Link to comment Share on other sites More sharing options...
96 EVO Posted December 25, 2023 Share Posted December 25, 2023 (edited) Is it a 'split ring' with the two holes on each side of the split? If so, you want snap ring pliers. Edited December 26, 2023 by 96 EVO 1 Link to comment Share on other sites More sharing options...
Robert92867 Posted December 26, 2023 Author Share Posted December 26, 2023 Not a snap ring. That would be easy. And the split ring is round, like 3/64" diameter high strength wire that has no holes in it. I picture in my mind a machined tube, perhaps split twice, that can be fitted over the ring once it is placed in the groove and then a hose clamp compressing this machined tube, then driving the Stop ring over the split ring in one quick movement. That would be a good tool to include in the rebuild kit. Link to comment Share on other sites More sharing options...
lotosrggp1 Posted December 26, 2023 Share Posted December 26, 2023 See page 12 of the manual: http://jatonkam35s.com/CUCVTechnicalmanuals/1M-128.pdf, just a tube and hammer. Hopefully you had the armature tested, replaced the bearings etc to have a reliable unit if needed. 1 Link to comment Share on other sites More sharing options...
Robert92867 Posted December 27, 2023 Author Share Posted December 27, 2023 Yes, I have that manual. That process describes REMOVING the stop ring. That was easy. Link to comment Share on other sites More sharing options...
Robert92867 Posted December 28, 2023 Author Share Posted December 28, 2023 OEM parts look cool. Link to comment Share on other sites More sharing options...
lotosrggp1 Posted December 29, 2023 Share Posted December 29, 2023 Robert, I see what you mean. I think I would have made a plate with a hole a little larger than the shaft that could slide under the stop on 3 sides. ---------u------------ Make it long enough to clear the armature in a vice so the armature can be held by this device holding the shaft. Use a brass drift or lead hammer to tap the shaft down without damaging it. Without a vice you could use the same piece with a second without a center hole and a couple of bolts to make a puller. Tom Link to comment Share on other sites More sharing options...
