Air solenoid question - 2005 HR Navigator 45 ft. Located in area of rear tag axle. What is it and what does it do and how does it work? Thanks
  • Tom Cherry changed the title to Air solenoid question - 2005 HR Navigator 45 ft. Located in area of rear tag axle. What is it and what does it do and how does it wotk? Thanks
  • Frank McElroy changed the title to Air solenoid question - 2005 HR Navigator 45 ft. Located in area of rear tag axle. What is it and what does it do and how does it work? Thanks
Check your prints.  Sometimes the PN is on the prints.  Check or download our parts list,,.,probably in there as well. Look wt the prints and connections to answe your video questions. These are not a special valve.  Just a closed with no power….energize or provide power….coil then opens up the valve.  There is no need for an outlet hose or tube…but add one if that makes you happy.
Good Luck…
It’s also possibly the control for the tag lift. The tag axle will have a normal leveling and ride height set of lines to the air bags, and will also have a separate set of smaller air bags to raise the axle when the driver armrest switch is activated. Basically, the switch is wired to the leveling system, telling it to dump the tag axle air bags and inflate the bags that raise the axle a few inches.
