saflyer Posted February 21 Share Posted February 21 Went to the coach tonight. The two lights under the TV console were on. Nobody remembers turning then on. I tried to tap them off but no luck. Operating on battery power. Since they are both behaving the same way it must be a system problem. Where should I look short of disconnecting the house batteries? Ed 2005 HR Ambassador Link to comment Share on other sites More sharing options...
Solution Dwight Lindsey Posted February 21 Solution Share Posted February 21 Rotate your headlight switch to the off position 1 Link to comment Share on other sites More sharing options...
Tom Cherry Posted February 21 Share Posted February 21 11 hours ago, saflyer said: Went to the coach tonight. The two lights under the TV console were on. Nobody remembers turning then on. I tried to tap them off but no luck. Operating on battery power. Since they are both behaving the same way it must be a system problem. Where should I look short of disconnecting the house batteries? Ed 2005 HR Ambassador Check page 315 of your manual. If you haven’t reviewed the electrical sections, 8 & 9, that might be advisable.. Link to comment Share on other sites More sharing options...
saflyer Posted February 21 Author Share Posted February 21 12 hours ago, Dwight Lindsey said: Rotate your headlight switch to the off position Interesting. I was rotating the switch to see if there is a set screw or some such to remove the knob. I need to do that to remove the switch since my headlights don’t work, bright or dim. I only have parking lights. So that brings up the subject of how to remove the switch. I can access the back of the switch by removing the cover of the dash but need to remove the knob to remove the switch. How is this accomplished. Am I approaching this correctly or should I troubleshoot elsewhere first? Is there a good source for the switch? I have heard it’s an old standard that should be available at any auto parts store. BTW, thanks Tom for going easy on me. Link to comment Share on other sites More sharing options...
Frank Bergamo Posted February 21 Share Posted February 21 The switch has a button on it to release the knob. Wiggle the knob as you press the button and it should pop out. Hope this helps, good luck! Link to comment Share on other sites More sharing options...
saflyer Posted February 21 Author Share Posted February 21 (edited) 23 minutes ago, Frank Bergamo said: The switch has a button on it to release the knob. Wiggle the knob as you press the button and it should pop out. Hope this helps, good luck! Can you be more specific about the location of the button? Is it on the part of the switch behind the dash? I have a very limited view of it there due to the left vent hose obstructing the view. I could remove the hose but am afraid this will just introduce new problems. Doing it mostly by feel now. Edited February 21 by saflyer Change word Link to comment Share on other sites More sharing options...
cbr046 Posted February 21 Share Posted February 21 35 minutes ago, saflyer said: So that brings up the subject of how to remove the switch. I can access the back of the switch by removing the cover of the dash but need to remove the knob to remove the switch. How is this accomplished. Headlight switch knob removal - In my case it wasn't the switch, but after fiddling with several harnesses the lights mysteriously started working. I couldn't find any suspect connections . . . . Or in your case maybe it is the switch . . . - bob 1 Link to comment Share on other sites More sharing options...
saflyer Posted February 21 Author Share Posted February 21 7 minutes ago, cbr046 said: Headlight switch knob removal - In my case it wasn't the switch, but after fiddling with several harnesses the lights mysteriously started working. I couldn't find any suspect connections . . . . Or in your case maybe it is the switch . . . - bob Thanks. Very useful. Mine is slightly different as to the nut that holds it to the dash. Shouldn’t be a problem. I’ll go back out and try to locate the button again. Link to comment Share on other sites More sharing options...
cbr046 Posted February 21 Share Posted February 21 6 minutes ago, saflyer said: Thanks. Very useful. Mine is slightly different as to the nut that holds it to the dash. Shouldn’t be a problem. I’ll go back out and try to locate the button again. Oh yeah, the headlight knob MUST in the fully extended position (lights on). I used a coin under my finger/thumb to keep from poking into said digit. You still have to fiddle with shaft and button. - b Link to comment Share on other sites More sharing options...
saflyer Posted February 22 Author Share Posted February 22 On 2/21/2024 at 10:02 AM, saflyer said: Can you be more specific about the location of the button? Is it on the part of the switch behind the dash? I have a very limited view of it there due to the left vent hose obstructing the view. I could remove the hose but am afraid this will just introduce new problems. Doing it mostly by feel now. Success. Got the light switch out. Now to test it. Link to comment Share on other sites More sharing options...
cbr046 Posted February 22 Share Posted February 22 7 minutes ago, saflyer said: Success. Got the light switch out. Now to test it. You can take it apart, too. Bend the two tabs on sides and everything comes apart. *AND* (the best part) it'll go back together again! - bob Link to comment Share on other sites More sharing options...
saflyer Posted February 23 Author Share Posted February 23 7 hours ago, cbr046 said: You can take it apart, too. Bend the two tabs on sides and everything comes apart. *AND* (the best part) it'll go back together again! - bob Got the switch out. There are far more wires than I expected. They are all white and only a couple labeled and they were for panel dimming. Oh well, it’s off to the shop we go. Link to comment Share on other sites More sharing options...
cbr046 Posted February 23 Share Posted February 23 This might help. Just ignore the colors. Link to comment Share on other sites More sharing options...
saflyer Posted February 23 Author Share Posted February 23 (edited) 19 hours ago, cbr046 said: This might help. Just ignore the colors. This is mine. At least six wire all of which are white and only three labeled. Behind my abilities. Took it to the shop. Edited February 23 by saflyer Link to comment Share on other sites More sharing options...
cbr046 Posted February 26 Share Posted February 26 Again, driving home on I-20 last night the lights went out in Georgia. #$&%@!!! Pulled in a truck stop, wiggled all the harnesses & connectors on the pc board in the FRB, wiggled all the relays and connections I could find, went inside and wiggled the harnesses under the transmission, beat HARD on the dash, turned on the lights and they WORKED! Then I repeated all that wiggling and pounding with the lights on and couldn't get them to fail. Drove an hour today lights on and couldn't get them to fail. Oh, and my on-off-on Warning Light went out and stayed out after dumping the black & grey tanks. It had been on since leaving Friday. Never a dull moment. - bob Link to comment Share on other sites More sharing options...
