Kenster Posted March 15 Share Posted March 15 Does anyone know who makes the spring loaded interior manual pull down screen on the drivers and passenger side? A sticker said 21603212. With the exception of the fabric, they are the same is the electric drivers and passengers front blind. All four have X style lattice bracing. Link to comment Share on other sites More sharing options...
BradHend Posted March 15 Share Posted March 15 Not sure but could I ask why you are replacing them? Link to comment Share on other sites More sharing options...
Scotty Hutto Posted March 15 Share Posted March 15 I *believe* they may be made by AutoMotionShade. https://automotionshade.com/en-us/ The full part numbers from the Dealer Parts List are FLX-615MW-3600-4200 (36”) and FLX-615MW-3200-4200-51 (32”). While not listed on the website, it may be worth a call to their support number Link to comment Share on other sites More sharing options...
Kenster Posted March 15 Author Share Posted March 15 I believe the passenger side may have a weak spring as it will not retract every time. I have disassembled it and it's appears to be a pretty simple setup. Link to comment Share on other sites More sharing options...
Scotty Hutto Posted March 15 Share Posted March 15 @stacyhall Do you still have yours? Link to comment Share on other sites More sharing options...
Kenster Posted March 15 Author Share Posted March 15 Yes I do. I have both sides and the two Electric fronts. Link to comment Share on other sites More sharing options...
BradHend Posted March 15 Share Posted March 15 You are able to make the spring stronger by adding more tension. I did both of mine for the same reason. Also sprayed some dry graphite lube in the tube to help things move. Link to comment Share on other sites More sharing options...
Bob Wightman Posted March 15 Share Posted March 15 Following. My 2006 HR Scepter the shades on both driver & passenger side won't retract (I have to roll them up by hand) and have been on my list to fix, just haven't gotten that far down the list since purchasing in December 2023. The power shade on the passenger side of the window works but does not completely retract, also on the list to figure out why (since the drivers side does) but hasn't been in my way so its towards the bottom of the list next to the other two shades. I figure both should be easy to fix but will follow for advice from others that have already taken these tasks on and how they completed them. Link to comment Share on other sites More sharing options...
