Bigdogracing Posted April 18 Share Posted April 18 Hello. Well apparently our hydraulic motor has died. The new one from Lippert is around $1300 but I ran across this place that says they have the same motor for $395. Yea I am skeptical but found it on another forum and several people say they have used it successfully but curious about using it on the Monaco since this motor powers two large slides and the jacks. Open to any experience or thoughts from all the experts here! Thanks Link to comment Share on other sites More sharing options...
vito.a Posted April 18 Share Posted April 18 Have you looked into having your original hydraulic pump rebuilt? Is it the electrical end, or hydraulic end that's not working? If the electric end, most electric motor rebuilder should be able to fix it. I'd try a place that rebuilds starters. Link to comment Share on other sites More sharing options...
Bigdogracing Posted April 18 Author Share Posted April 18 I am not sure. The tech just said it need replaced. I did find someone to rebuild it but that takes weeks and I need one like yesterday of course! Link to comment Share on other sites More sharing options...
Ivan K Posted April 18 Share Posted April 18 My opinion, if the pump in fact works, it doesn't matter how many functions it feeds since it only runs one at a time. Link to comment Share on other sites More sharing options...
Frank Bergamo Posted April 18 Share Posted April 18 Not knowing what exactly is the problem, hard to give any advice to a solution. I would first start with the relay switch on the pump/motor to make sure that is not the problem. Common failure point and fairly simple fix. If no joy there, then the electric end on the pump would be next. The pump/motor runs such a short period of time, that is an unlikely failure point. Not to say that it does not fail, but I would be sure to rule out the other components before throwing money at it. Ask the tech specific questions concerning the components, making sure he has checked them before committing to a new pump. Hope this helps. Link to comment Share on other sites More sharing options...
