powersltc Posted July 31, 2020 Share Posted July 31, 2020 (edited) Ron P. 2004 Monaco Executive I believe I need a resistor replaced in my 2004 Monaco Executive. Has anyone had this problem and can tell me the location of the blower motor/resistor in the 2004 Monaco Executive? Also, do you have a source and part number for the resistor? Thanks. Ron P. 2004 Monaco Executive Edited July 31, 2020 by powersltc Forgot something Link to comment Share on other sites More sharing options...
Tom Cherry Posted August 1, 2020 Share Posted August 1, 2020 1 hour ago, powersltc said: Ron P. 2004 Monaco Executive I believe I need a resistor replaced in my 2004 Monaco Executive. Has anyone had this problem and can tell me the location of the blower motor/resistor in the 2004 Monaco Executive? Also, do you have a source and part number for the resistor? Thanks. Ron P. 2004 Monaco Executive Ron, Go to the DOWNLOADS section. You will find, on the RIGHT side....the PARTS LIST. DOWNLOAD THIS. You MUST save it as a PDF and get it on your computer. Wherever you want it. NOW....once you see it (or the icon if you put it on your desktop like all the old timers do.... OPEN it with your Adobe Reader. THEN go to the EDIT tab at the top. The DROP DOWN will have a FIND (magnifying glass). This is the BEST tool there is.... Type in resistor.... BINGO...that takes you to page 48. Someone wrote a story....just for you. IT has info on the PN, WHERE and HOW to get into it..... That is one of the best writeups I have seen. It is also for a 2004 Signature. You lucked out..... Good Luck.... Link to comment Share on other sites More sharing options...
powersltc Posted August 1, 2020 Author Share Posted August 1, 2020 Ron P. 2004 Monaco Executive Hello Tom. Not sure where the download section is located. Please advise. Ron P. Link to comment Share on other sites More sharing options...
Frank McElroy Posted August 1, 2020 Share Posted August 1, 2020 Go to Browse - select Downloads - select Categories - Parts List is on top. Here is a link. https://www.monacoers.org/files/category/16-parts-list/ Link to comment Share on other sites More sharing options...
Tom Cherry Posted August 1, 2020 Share Posted August 1, 2020 14 minutes ago, powersltc said: Ron P. 2004 Monaco Executive Hello Tom. Not sure where the download section is located. Please advise. Ron P. It is on the MAIN or HOME page. Look for the BROWSE word....and the main page has Bill D's Motor Home in the picture. The tool bar or tab undeneath it. It has tabs or drop downs. Downloads is the fourth one (L to Right). Click on it....then follow the instructions that I gave you. Link to comment Share on other sites More sharing options...
powersltc Posted August 1, 2020 Author Share Posted August 1, 2020 Ron P. 2004 Monaco Executive Hello Tom. Not sure where the download section is located. Please advise. Ron P. Thanks. Got it. Link to comment Share on other sites More sharing options...
michaelivan Posted August 2, 2020 Share Posted August 2, 2020 Ron, I had posted about this a couple of months ago. Here is my post... I had the same issue with the resistor. It is fairly easy to access. Here are the links to the repair that I used. https://www.irv2.com/forums/f115/dash-a-c-blower-speed-switch-117793.html https://www.irv2.com/forums/f115/a-c-resistor-pack-on-a-windsor-302094.html I ordered the resistor online from Radio Shack. Now have all 4 speeds. Link to comment Share on other sites More sharing options...
