diys1 Posted September 6, 2020 Share Posted September 6, 2020 I have developed a leak in the tank on the tranny cooler. I have had it welded twice so that isn't working very good. It is getting a crack in the tank in the same place and the weld isn't holding. I don't see any stress on it in that area but maybe the vibration is breaking it. If anyone knows of a source for the older Monaco parts please let me know. The radiator is 12" x 22" and mounts on top and r side I could try another weld job but would like to replace it. Thanks for any help JimJ 2003 Diplomat Link to comment Share on other sites More sharing options...
Dr4Film Posted September 6, 2020 Share Posted September 6, 2020 Jim, It would be easier and maybe even cheaper to have a shop like CG&J or Source Engineering make you one based on the one that you have now. Take dimensions, mounts and opening locations, etc. then send them an email to those two shops to see what they can do. Link to comment Share on other sites More sharing options...
daveyjo Posted September 6, 2020 Share Posted September 6, 2020 https://cgj.com/ CJ@C did mine. Works OK. Dave Jones 2005 HR Scepter Link to comment Share on other sites More sharing options...
dl_racing427 Posted September 7, 2020 Share Posted September 7, 2020 I use Setrab coolers on my racecars. They're extremely efficient, rugged, and the price may be more reasonable than a custom cooler. They make many sizes and configurations, I'm sure they have something that would work well in a coach application. Link to comment Share on other sites More sharing options...
Dude_from_Florida Posted September 7, 2020 Share Posted September 7, 2020 I have a brand new Modine Radiator and Charge Air Cooler also with Transmission Cooler. Bought it for my 2001 Monaco Diplomat but never installed it. Tampa radiator shop was able to re-core the old ones. This is the entire assembly with frame and shroud. Specifics: Modine Radiator/Charger Air cooler total dimensions are 43 1/4" wide mount bracket to mount bracket on top Bottom measures 46 3/4" mount bracket to mount bracket. In the pictures there is a lip on the bottom actual radiator is 44" and 40 1/4 high top to bottom The whole assembly measures 13 1/2" wide with the shroud and set up for remote hook up. The Radiator and Charger Air Cooler is stacked with the Radiator on bottom. Dimensions of Intercooler: Cooling unit 34"wide, 19" tall and 3" thick. Overall 47"wide, 19"tall and 11 1/2"thick. The Charger Air Cooler has two ports one on either side intake ports are cast aluminum and measure 3 1/2" ID 4 1/8" OD. STEEL SHROUD (not plastic) is tapered to the front and measures 38" wide X 32" high in the front closest to the radiator and 34 1/2" wide X 30 1/2" high in the rear. Round hole for fan measures 31" in diameter and sticks out from the coils about 10" BRAND NEW MODINE COMBINATION RADIATOR AND CHARGE AIR COOLER WITH TRANSMISSION COOLER WITH STEEL SHROUD NEW STILL IN THE CRATE FOR DIESEL PUSHER CLASS A MONACO / HR MOTORHOME MODEL# 01807106-1A20309 WITH STEEL SHROUD I AM IN LAKELAND (Between Orlando and Tampa) PAID $2,500 - WILL TAKE $1,500 and WILL HELP SHIP OR DELIVER Link to comment Share on other sites More sharing options...
diys1 Posted September 26, 2020 Author Share Posted September 26, 2020 Just a followup on the transmission cooler radiator leak. The tank developed a leak for the second time, first time was 2 years before, I removed it and had it tig welded at a machine shop and it looked good but it developed another leak after around 400 miles so filled up with tranny fluid @$52/gal and limped to my destination. Took it off again, getting pretty good at this, took it to a machine shop and explained where it was splitting and that I wanted a patch welded over the corner where it was leaking. They Tig welded the crack then welded a patch over it. I think it will hold only time will tell.Thanks for all the helpful replies but I was forced to get it done quick so the patch job. ThanksJimJ Link to comment Share on other sites More sharing options...
