Hypoxia Posted January 16, 2021 Share Posted January 16, 2021 After much consideration I decided to replace the reel and hose on the coach. The 50' reel is 1" wider than the original 35' hose reel and I had the space. On a 45' coach it seemed like I was always a foot short of reaching the hose bib. It arrived today so I , of course had to immediately install it! The nut that holds it on the reel is 1 1/2" and the only socket that size I have is fairly long. The space is small so I used a pipe wrench to turn the socket. It was not easily turned so I called Glendenning to make sure I wasn't going to break something. I think it was about 5 minutes before they closed down for the weekend. Michael explained that I need to give it a little more love to break the nut loose, which I did with some pipe for an extension. It did get a little more complicated but in the end he was available after hours which helped greatly! There has been some discussion about the hose connection on the Glendinning Hose Reel, here are photos of mine, Model M Hose Reel. Link to comment Share on other sites More sharing options...
willbo777 Posted January 16, 2021 Share Posted January 16, 2021 I just replaced mine as well, although I had to remove the entire unit to get to the nut, not a big deal. Link to comment Share on other sites More sharing options...
pwhittle Posted January 17, 2021 Share Posted January 17, 2021 Glendinning support has always been great for me too! Paul Link to comment Share on other sites More sharing options...
cor460 Posted January 17, 2021 Share Posted January 17, 2021 What kind of hose are you going back with? Our hose keeps twisting and is hard to retrack at times. I would also like to increase the length as our hose is about 15 foot long. Link to comment Share on other sites More sharing options...
Hypoxia Posted January 17, 2021 Author Share Posted January 17, 2021 7 hours ago, cor460 said: What kind of hose are you going back with? Our hose keeps twisting and is hard to retrack at times. I would also like to increase the length as our hose is about 15 foot long. Glendinning Model M 50' Long Hose and Spool is an inch wider than the 35' hose spool. 2 Link to comment Share on other sites More sharing options...
