powersltc Posted February 28, 2021 Share Posted February 28, 2021 I have a 2004 Monaco Executive. My Hadley air horns don't always work. I heard that I could attach a horn button directly to the solenoid. Anyone know where the solenoid may be located on a 2004 Monaco Executive? Link to comment Share on other sites More sharing options...
bellr1968@gmail.com Posted February 28, 2021 Share Posted February 28, 2021 On my 08 Dynasty it was located behind the generator. Replaced the solenoid and worked great for 3 years before I sold the coach. Link to comment Share on other sites More sharing options...
tcbrow Posted February 28, 2021 Share Posted February 28, 2021 Here's a tip regarding air horns. When you settle in for the night put a "chip clip" on the switch so it won't go off when the cat steps on the switch at 5 am like mine did. Link to comment Share on other sites More sharing options...
Dennis H Posted March 1, 2021 Share Posted March 1, 2021 Mine did the same until I replaced the solenoid and they've worked well since. The solenoid is in the generator compartment, passenger side on one of the vertical struts above your air drain valve.....Dennis Link to comment Share on other sites More sharing options...
powersltc Posted March 1, 2021 Author Share Posted March 1, 2021 Thanks for the comments. I'll try your suggestions. Link to comment Share on other sites More sharing options...
vegaman19760 Posted March 1, 2021 Share Posted March 1, 2021 23 hours ago, tcbrow said: Here's a tip regarding air horns. When you settle in for the night put a "chip clip" on the switch so it won't go off when the cat steps on the switch at 5 am like mine did. Our 2 cats are gone now to be with their brothers and sisters in heaven. But we have had that same experience when the cats used the steering wheel to climb onto the dash as night. Stay safe, Stay well, Safe travels Link to comment Share on other sites More sharing options...
Bob R Posted March 3, 2021 Share Posted March 3, 2021 I had a similar problem and found that the wire connecting the 12 V to the solenoid had loosened. The horn worked sometimes and other times not. Bob Raffety 2005 Dynasty Link to comment Share on other sites More sharing options...
powersltc Posted March 3, 2021 Author Share Posted March 3, 2021 Thanks. Link to comment Share on other sites More sharing options...
Moonwink Posted March 5, 2021 Share Posted March 5, 2021 On my Trek, I have to "wake up" the horn every day when I'm driving or else it doesn't work when I need it. After hitting the horn button 5 or 10 times, it starts working and will give a blast every time I press the button. I suspect the solenoid valve is sticking. If I knew where it was, I'd try getting a little silicone in it's air line before replacing it. I guess moisture builds up inside the air line over the years and causes problems. Link to comment Share on other sites More sharing options...
powersltc Posted March 5, 2021 Author Share Posted March 5, 2021 Thank for the comments. I changed my solenoid and the horn still does not work. Link to comment Share on other sites More sharing options...
Moonwink Posted March 5, 2021 Share Posted March 5, 2021 Sorry to hear replacing the solenoid didn't fix your problem. I found these cleaning instructions for the solenoid and figured I might as well post them for others reading this post. Link to comment Share on other sites More sharing options...
StephenW Posted March 5, 2021 Share Posted March 5, 2021 Thanks Moonwink for this information as the air horn in my Dynasty has stopped working. I will try this cleaning procedure as well as check the electrical connections on the solenoid as recommended by others. Thanks again. Link to comment Share on other sites More sharing options...
Bob R Posted March 9, 2021 Share Posted March 9, 2021 (edited) A friend stored his RV outside. Eventually the air horns failed. We found that the horns themselves were plugged up by dirt dobber nests. We sprayed water into the outlet of the horns, washed the nests out, removed the horn diaphrams and cleaned them. After reassembly the horns worked once more. Bob Raffety 2005 Monaco Dynasty Edited March 9, 2021 by Bob R misspelling corrections Link to comment Share on other sites More sharing options...
powersltc Posted March 12, 2021 Author Share Posted March 12, 2021 Hello. Ron P. 2004 Monaco Executive I changed out my air solenoid. Tested the horn and nothing happened. A couple days later, I got on the road to go to Bethany Beach. Hit the horn and it works. I'll see what happens Wednesday when I pull out. Well, my horn is still working. Swapping out the air solenoid must have done the trick. Thanks everyone for your assistance. Link to comment Share on other sites More sharing options...
