Skipperira Posted May 6, 2021 Share Posted May 6, 2021 I notice there isn’t any fluid in the coolant level tank, when cold. I’d like to add what is needed and am not sure of the specific brand or type for the 8.8 l Any advice and thank you, all Link to comment Share on other sites More sharing options...
Joelsheriff Posted May 6, 2021 Share Posted May 6, 2021 Use a decent brand of 50/50 coolant. Should be yellow but first what is engine temp running at when on highway? Should be in high 170s and is radiator clean. Link to comment Share on other sites More sharing options...
Skipperira Posted May 6, 2021 Author Share Posted May 6, 2021 I’ll note that temp, next time out, I’ve just run 1500 miles well within limits. Why yellow? Link to comment Share on other sites More sharing options...
Upsman85 Posted May 6, 2021 Share Posted May 6, 2021 ISL has what they call a wet sleeve around the piston cylinder and the coolant has to be approved for anti cavitation! Link to comment Share on other sites More sharing options...
Bill Hines Posted May 6, 2021 Share Posted May 6, 2021 This is a complicated topic. Most owners have gone to OAT coolants and away from SCA. I changed over in 2013. The easiest way to explain what to use is this video, a little long but watch the whole thing because it will inform you of importance of Diesel Coolant. 1 Link to comment Share on other sites More sharing options...
ktloah Posted May 6, 2021 Share Posted May 6, 2021 Just had mine changed and flushed at cummins. They used GREEN antifreeze with SCA. I have an SCA filter that I change twice a year. Link to comment Share on other sites More sharing options...
guy_ethier Posted May 6, 2021 Share Posted May 6, 2021 Skipper. Just changed mine yesterday, after going 12 years since the last time I changed 'er out....yikes! I originally had the green stuff in there from the factory. When I went to test it for SCA the sample I drew came out rusted in color and I decided it was time to drain, clean, flush and change it over to OAT extended coolant from Cummins. Took me the better part of 6 hours by myself but the Cummins Restore Plus did an excellent job of removing all of the contaminants that were in there. When I first added the Restore Plus, after I had drained the brown rusted coolant, then took the coach out for a 90 minute run as recommended by Cummins, the fluid came out black when I drained the Restore Plus out of the lower hose. Added tap water 5 more times with a final rinse of distilled water until the color was almost clear. I then added 8 jugs of OAT extended coolant premix, as recommended again by Cummins, and now no more adding DCA, just testing and topping up the coolant as required. Long job, but worth it. Cummins has excellent information on their website for how to do this. It is not necessary to get the whole system purged of the green ethylene glycol that was originally in there, even though I think I came close, as they tell you that you can have a certain percentage of the other coolant in there without worry when adding the red stuff (OAT extended), as long as they are both ethylene glycol or propylene glycol based. The plastic type of OEM coolant recovery tank that Monaco used is almost impossible to see coolant levels. I use a clean dipstick when checking but others have swapped out their OEM plastic tank for a more durable steel tank. That will be in my future as well. Link to comment Share on other sites More sharing options...
96 EVO Posted May 6, 2021 Share Posted May 6, 2021 Color of new coolant means nothing these days! The original coolant in my 08' was lime green. First change I did, new HD diesel coolant w/ SCA was purple. Next change, I used extended life HD diesel coolant w/ SCA, coolant is red. 1 Link to comment Share on other sites More sharing options...
Joelsheriff Posted May 6, 2021 Share Posted May 6, 2021 I stand corrected, I was under the impression the coolant color was so that you used the right product for the right application. Diff products and mixtures for diff engines and mixtures. Never too old to learn. That's what I love about this forum. Link to comment Share on other sites More sharing options...
William Posted May 6, 2021 Share Posted May 6, 2021 I used fleetguard es compleat https://www.amazon.com/dp/B07XB2QB4J?psc=1&ref=ppx_yo2_tab_ap_product_details Link to comment Share on other sites More sharing options...
Bill Hines Posted May 7, 2021 Share Posted May 7, 2021 I changed coolant to Final Charge. You can buy at any Walmart. Link to comment Share on other sites More sharing options...
Roger 2006 HR Endeavor PDQ Posted May 7, 2021 Share Posted May 7, 2021 On 5/6/2021 at 8:19 AM, guy_ethier said: The plastic type of OEM coolant recovery tank that Monaco used is almost impossible to see coolant levels. I use a clean dipstick when checking but others have swapped out their OEM plastic tank for a more durable steel tank. That will be in my future as well. Guy, I installed a steel surge tank and a new radiator on our ' 06 HR Endeavor in 2016. Both items came from Source Engineering. One very nice feature of the surge tank is that it has a sight glass that allows me to check the coolant level without removing the cap. Roger 2006 HR Endeavor PDQ Link to comment Share on other sites More sharing options...
guy_ethier Posted May 7, 2021 Share Posted May 7, 2021 Roger. Did you do the recovery tank install yourself and, if you did, was it pretty straightforward or did you have to modify it a bit? I would love to see some pics of your install and any problems/ adjustments you had to make. Also, what price did the new coolant tank set you back? Thanks☺️ Link to comment Share on other sites More sharing options...
Joelsheriff Posted May 7, 2021 Share Posted May 7, 2021 I just replaced mine with the last tank Chris T had in stock. All steel with better visual, tank $500 shipping $50 install under extended warranty. Took tech 2.5 hrs (he claims) and had to get additional fittings. Link to comment Share on other sites More sharing options...
96 EVO Posted May 7, 2021 Share Posted May 7, 2021 1 hour ago, Joelsheriff said: I just replaced mine with the last tank Chris T had in stock. Nice ! Link to comment Share on other sites More sharing options...
Roger 2006 HR Endeavor PDQ Posted May 7, 2021 Share Posted May 7, 2021 2 hours ago, guy_ethier said: Roger. Did you do the recovery tank install yourself and, if you did, was it pretty straightforward or did you have to modify it a bit? I would love to see some pics of your install and any problems/ adjustments you had to make. Also, what price did the new coolant tank set you back? Thanks☺️ Guy, I could have changed it out myself, but the major job was the radiator replacement. The shop already had the back panels out for the radiator, so changing the tank was especially easy. As I recall, the price was somewhere around $350--not bad for something you won't have to worry about agagin. Roger 2006 Endeavor PDQ Link to comment Share on other sites More sharing options...
ktloah Posted May 7, 2021 Share Posted May 7, 2021 Got my tank at Source Engineering in Oregon. Jim was very helpful in info and it bolted right up to the existing holes Link to comment Share on other sites More sharing options...
