David RUSSELL Posted May 22, 2021 Share Posted May 22, 2021 Any hints on lube for brake calipers on 2003 Monaco knight. Read there was a special way to do this,cannot find info.Do you lube just slide bolts,or pad rails as well?. Thank you for any info. Greatly appreciated. David RUSSELL Link to comment Share on other sites More sharing options...
Gary M Posted May 22, 2021 Share Posted May 22, 2021 Have you tried watching Youtube videos on the subject. Link to comment Share on other sites More sharing options...
Dennis H Posted May 22, 2021 Share Posted May 22, 2021 Just the pins. And be conservative....Dennis Link to comment Share on other sites More sharing options...
rpasetto Posted May 23, 2021 Share Posted May 23, 2021 If you bring it in for lube, give the mech. the Monaco lube chart for your coach and the specs for lubricant types. I think that's in all the Monaco owner manuals. Link to comment Share on other sites More sharing options...
Frank Bergamo Posted May 23, 2021 Share Posted May 23, 2021 David, do you have Meritor or Bendix brakes. The Meritor system uses clay based grease, a very specific process. Most shops just use chassis grease not knowing what type of system you have. Need to figure out what system you have before lubing brake calipers. Hope this helps. Link to comment Share on other sites More sharing options...
scottjo02 Posted May 23, 2021 Share Posted May 23, 2021 Hi David Since you mentioned calipers, I imagine you have air over hydraulic Bosch disc brakes the same as I do on my 02 Knight. If this is not the case, ignore all of this message. Here is a link to the Bosch Pin Slide Disc Brake service manual. It is 60 pages and very good. Lubrication is covered on page 43. http://www.weindex.info/pdf/Brake/2.pdf Further information, you may be aware that the above brake system had a NHTSA recall #02V278000. The recall was a result of severe brake overheating probably caused by moisture in the brake fluid that caused the phenolic brake pistons to expand and not retract properly. I had two or three of these overheating events and had complete brakes replaced on the offending axle each time. In order to monitor the situation I installed a themocouple temperature monitoring system on each backing plate. It alerts me it the brakes are begining to overheat which usually occurs at lower speeds whent the exhaust brake is not effective. The other and most important thing I do now is flush the brake fluid system every two years. It is relativly easy and only needs about two or three cans of dot 4 synthetic brake fluid. I use the Harbor Freight brake bleeder #92924 with my shop air. Scott Link to comment Share on other sites More sharing options...
David RUSSELL Posted May 24, 2021 Author Share Posted May 24, 2021 Thank you for this excellent information. Greatly appreciated. David RUSSELL Link to comment Share on other sites More sharing options...
rambler07 Posted May 24, 2021 Share Posted May 24, 2021 If you have brakes that require brake fluid, if you open the can of fluid and do not use it all! junk the can ! brake fluid left in the can will absorb moisture from the the surrounding air. This I know from working in a brake lab for 22 years. We purchased our fluid in large containers, before we would use any of the fluid we had to pull a vacuum on the container. A can of fluid you purchase will become contaminated in a short time. a can is CHEAP not worth the trouble later on. Greg B. Link to comment Share on other sites More sharing options...
