Hinton8888 Posted May 27, 2021 Share Posted May 27, 2021 I totally floored that my one of my units only lasted 33 months and was not run that much . I called Dometic and they were Like you should have bought an extended warranty. My old units lasted for 23 years so I said why would I waste money. I called the Dometic U.S.A. ceo in Elkhart with no return call. How long is everyone getting out of new units. This unit was a 15k A/C only. I tried to keep it simple. It appears the issue is a coolant leak. The compressor starts Steve 1996 exec Link to comment Share on other sites More sharing options...
Gary M Posted May 27, 2021 Share Posted May 27, 2021 Ours is going on 4 years now. But again not a whole lot of use. Our OEM Carrier AC heat pump combo still working after 13 years. Link to comment Share on other sites More sharing options...
cbr046 Posted May 28, 2021 Share Posted May 28, 2021 Have a private AC tech find the leak, seal it and recharge the system. Best, - bob Link to comment Share on other sites More sharing options...
hitechpete Posted May 28, 2021 Share Posted May 28, 2021 13 hours ago, Hinton8888 said: I totally floored that my one of my units only lasted 33 months and was not run that much . I called Dometic and they were Like you should have bought an extended warranty. My old units lasted for 23 years so I said why would I waste money. I called the Dometic U.S.A. ceo in Elkhart with no return call. How long is everyone getting out of new units. This unit was a 15k A/C only. I tried to keep it simple. It appears the issue is a coolant leak. The compressor starts Steve 1996 exec We had a brand new one fail within a week on our Cedar Creek Champagne. When the engineer examined it he noticed that a bracket had been omitted on a long pipe between the compressor and condenser. He stated that he had replaced several new units suffering from the same manufacturing defect. Link to comment Share on other sites More sharing options...
Hinton8888 Posted May 29, 2021 Author Share Posted May 29, 2021 Peter N you said an engineer looked at you A/C. Where did they come from to look at it. Thanks steve Link to comment Share on other sites More sharing options...
Dr4Film Posted May 29, 2021 Share Posted May 29, 2021 I replaced the factory installed Dometic Low Profile Penguin AC/HP's with new ones in 2009/10. Coach was put in service 9/2001 Those were both replaced the winter of 2018/19 while in Florida with new Dometic Low Profile Penguin II's AC/HP. Those are still going strong. We use the AC's a lot both when traveling 6 months and while the coach sits in Florida for the other 6 months. I use it daily even while it sits hooked up under our winter home. It's my man cave plus I am always doing small repairs and upgrades during the winter. Link to comment Share on other sites More sharing options...
hitechpete Posted May 30, 2021 Share Posted May 30, 2021 (edited) On 5/29/2021 at 1:46 PM, Hinton8888 said: Peter N you said an engineer looked at you A/C. Where did they come from to look at it. Thanks steve The selling dealer came out and replaced the A/C unit. According to him, the missing bracket was due to a change of schematics. Apparently units with heat pumps are not affected as the pipe runs are shorter and don’t vibrate to the same extent. Edited May 30, 2021 by hitechpete Punctuation Link to comment Share on other sites More sharing options...
