[email protected] Posted June 24, 2021 Posted June 24, 2021 Fresh water pump is leaking and is covered in calcium. Would like to replace pump but the part number is no longer available. What replaced Shurflo pump 2088-422-144? Jack H Holiday Rambler Vacationer 37PCT
Dr4Film Posted June 24, 2021 Posted June 24, 2021 (edited) There are two Remco water pumps that are excellent. One model AES and one model ARV. Just depends on the number of amps each one draws and the maximum GPM. http://www.remcoindustries.com/aquajet-pump/ The AES model - 3.4 GPM with 6.5 amp draw http://www.remcoindustries.com/wp-content/uploads/2021/01/55AQUAJET-AES-Spec.pdf The ARV model - 5.3 GPM with 10 amp draw http://www.remcoindustries.com/wp-content/uploads/2021/01/55AQUAJET-ARV-Spec.pdf Edited June 24, 2021 by Dr4Film 1
Dr4Film Posted June 24, 2021 Posted June 24, 2021 (edited) I just came across this web site and water pump housing. Will this work? https://rdboutique.ca/boutique/en/replacement-parts/shurflo/shurflo-fresh-water-pump-upper-housing-p994c155/ Edited June 24, 2021 by Dr4Film
Luther Taylor Posted June 24, 2021 Posted June 24, 2021 Shurflo 2088-443-144 Freshwatersystems.com Good luck
Nevada Rob Posted June 24, 2021 Posted June 24, 2021 I just installed the Remco ARV 5.3 GPM pump in my coach. It is very quite. If you are very still inside the coach you can hear it, otherwise you don't even know it is on. They are not cheap but according to the RV repair shop here in town they are better built and are returned less often.
Gary M Posted June 24, 2021 Posted June 24, 2021 Called Shurflo and tech recommended this as a replacement. Works great.
Chuck B 2004 Windsor Posted June 25, 2021 Posted June 25, 2021 I recommend you install a high end strainer to keep particles out of the pump. Chuck B 2004 Windsor
