GoSkeeterPopGo Posted August 12, 2021 Posted August 12, 2021 Hey Yall, I have a 2001 HR Endeavor with the Cummins ISC330. Anyone know where the transmission temp sensor is located, and if there is a replacement part for it? My gauge reads "nill" so its either a bad sensor or a wiring issue? Thanks.
Ivan K Posted August 12, 2021 Posted August 12, 2021 Matt, look by the front of transmission pan for a loose or hanging single wire. Ours is 4060 series but I would believe the external sensor, not used by the ECM, is in the same location.
vito.a Posted August 12, 2021 Posted August 12, 2021 I also found the wire loose on ours. I reinstalled it and added a zip tie to retain it.
